cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Inter-vlan routing problem?
I have catalyst 2960 cisco switch having 8 vlans each one with ip helper address and and assign one port to the vlans, all vlans are then assigned to a trunk port the trunk port is connected to Cisco 3800 series router.  Cisco Router 3800 series Router have 2 interface one with the public IP and one with the private ip connected to to 2960 switch trunk port (NAT overload is enabled) now I want to configure inter vlan routing, I have created dhcp pool for every vlan in the router, I created gi0/1.2 sub interface on the router and enable encapsulation dot1q 2 for vlan 2 now computers on vlan to can recive ip from the dhcp pool and can ping public and private ip but cannot ping beyond public ip due to intervlan routing please help me the router configurations are as follow.
Current configuration : 1548 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
dot11 syslog
ip source-route
ip cef
--More--
ip dhcp pool noc
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 4.2.2.2
ip dhcp pool vlan2
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 4.2.2.2
ip name-server 4.2.2.2
ip name-server 66.0.28.45
archive
log config
  hidekeys
interface GigabitEthernet0/0
ip address 182.50.190.140 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
router rip
version 2
network 182.50.0.0
network 192.168.0.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 182.50.190.254
no ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip nat inside source list 101 interface GigabitEthernet0/0 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
2 RESPOSTAS
Hi Sayed
Your Router need know which is the" Inside" interface to NAT/PAT.
Try the follows:
ip nat inside
I hope this help ...
Cheers Bruno Rangel Please remember to rate helpful responses using the stars bellow and identify helpful or correct answers .
Hi Sayed how are you? I hope fine!
Did you solved your issue?
Please remember to rate helpful responses and identify the correct answers.
574
Apresentações
Kudo
Respostas
