cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
L2TP vpdn icmp between end point and LNS doesn't work
Hi guys!
I'm migrating a L2TP/vpdn connection from Cisco Router 7200 IOS to ASR1006 IOS-XE 15.2(4)S3 and everything appears to be right, the authentication is passing ok, the end-point takes an ip address but the major issue, the icmp between end-point and the LNS the icmp doesn't work.
If I test the same config with my 7200,it works fine.
We've added a new command in the ASR 1006 "aaa policy interface-config allow-subinterface" because the virtual sub interface wasn't bringing up.
I'm thinking some stranger behavior with the ASR1006, may a bug :-(
Does anyone here knows about this issue?
33
Apresentações
Útil
Respostas
CriarFaça o para criar o conteúdo
