cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Problema no Cisco SG300 28pp
Antes de acessar ele da apenas esse erro:
i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1i2c_status fail: 1
Após acessar:
i2c_status fail: 1
12-Oct-2013 19:26:37 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x12e6 dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:38 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x12e8 dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:39 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11ae dev_num 1 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:40 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11ac dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:41 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11b0 dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:42 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11b4 dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:43 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11b8 dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:44 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11bc dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:44 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11b2 dev_num 1 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:45 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11c0 dev_num 0 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:46 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11ac dev_num 1 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:47 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11b0 dev_num 1 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:48 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11b4 dev_num 1 val 0x0) was detected: POE is Disabled untill Reset
i2c_status fail: 1
12-Oct-2013 19:26:49 %HAL_config_poe-A-POEFailDetected: POE ERROR(i2c_read_mem failed addr 0x11b8 dev_num 1 val 0x0) was detected: POE is Disabled untill Reset
Lembrando que ao reiniciar o switch demora muito para subir cerca de 15 min, porem ainda não resetei nem fiz nenhuma atualização nele alguém tem ideia do que possa ser?
1 RESPOSTA
Bronze
Viva,
Viva,
Se após um factory default o problema persistir, o mesmo deverá ser trocado (RMA)
70
Apresentações
Útil
Respostas
CriarFaça o para criar o conteúdo
