cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Problema Router 1905
Estou com um problema grave, meu router (Router Cisco 1905) quando inicia trava e depois de 5min rebuta, não sei mais o que fazer, alguém pode me ajudar, segue abaixo erro.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.09.25 10:12:43 =~=~=~=~=~=~=~=~=~=~=~=
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco CISCO1905BR-SEC/K9 (revision 1.0) with 229376K/32768K bytes of memory.
Processor board ID TSP1815ACCP
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
SYSTEM INIT: INSUFFICIENT MEMORY TO BOOT THE IMAGE!
%Software-forced reload
 10:11:05 BRT Thu Sep 25 2014: Breakpoint exception, CPU signal 23, PC = 0x21D33F7C
   Possible software fault. Upon reccurence, please collect
   crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 0x21D2D07Cz 0x21D2B3ACz 0x23B39078z 0x2568AB84z 0x239AE950z 0x239AEAE0z 0x2399DB90z 0x2399DCC8z 0x2399DD6Cz 0x2399DC20z 0x2399DD6Cz 0x2399DC20z 0x2399DD6Cz 0x2399EF78z 0x239ABEA8z 0x239B01DCz
$0 : 00000000 00000000, AT : 00000000 287E0000, v0 : 00000000 00000000, v1 : 00000000 00000000
a0 : 00000000 2A945F10, a1 : 00000000 00000001, a2 : 00000000 00000000, a3 : 00000000 00000000
t0 : 00000000 21DEF11C, t1 : 00000000 50009FE1, t2 : 00000000 21019C18, t3 : FFFFFFFF FFFF00FF
t4 : 00000000 21019C18, t5 : 00000000 00000000, t6 : FFFFFFFF 80011800, t7 : 00000000 00000C28
s0 : 00000000 00000000, s1 : 00000000 27FE0000, s2 : 00000000 00021014, s3 : 00000000 00021014
s4 : 00000000 239B5848, s5 : 00000000 00000000, s6 : 00000000 00000000, s7 : 00000000 00000000
t8 : 00000000 00000C40, t9 : 00000000 00800118, k0 : 00000000 504080E1, k1 : FFFFFFFF FFFFFFFE
gp : 00000000 287E1B00, sp : 00000000 294EC528, s8 : 00000000 294EC590, ra : 00000000 21D322AC
EPC  : 21D33F7C, ErrorEPC : 80412BC4, SREG     : 50009FE3
MDLO : 00000E01, MDHI     : 00002000, BadVaddr : 00000000
CacheErr_Icache : 0x007F7F00 - 00001EF8, CacheErr_Dcache : 0x00000000 - 00002710
TagLo_Icache : 0x00000000 - 21009B83, DataLo_Icache : 0xAE600000 - 12800004
DataHi_Icache: 0x00000000 - 00000001
TagLo_Dcache : 0x00000000 - 287DDD03, TagHi_Dcache : 0x00000000 - 087D9D01
DataLo_Dcache: 0x0000000A - 21DF69FC, DataHi_Dcache : 0x00000000 - 00000004
TEXT_START : 0x210077D8
DATA_START : 0x256AAF00
Cause 00000024 (Code 0x9): Breakpoint exception
File usbflash0:crashinfo_20140925-101105-BRT open failed (-1): No more root directory entries available
File usbflash0:crashinfo_20140925-101133-BRT open failed (-1): No more root directory entries available
=== Flushing messages (10:11:43 BRT Thu Sep 25 2014) ===
Buffered messages:
Queued messages:
*Sep 25 13:11:43.179: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Jan  2 00:00:03.595: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = ipbasek9 and License = ipbasek9
*Jan  2 00:00:03.787: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = securityk9 and License = securityk9
*Jan  2 00:00:04.063: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c1900 Next reboot level = datak9 and License = datak9
*Sep 25 13:10:40.739: c3600_scp_set_dstaddr2_idb(184)add = 80 name is Embedded-Service-Engine0/0
*Sep 25 13:10:55.791: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Initialized
*Sep 25 13:10:55.795: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0  State changed to: Enabled
*Sep 25 13:10:56.879: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
*Sep 25 13:10:56.879: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Sep 25 13:10:57.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
*Sep 25 13:10:57.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Sep 25 13:11:01.983: %USBFLASH-5-CHANGE: usbflash0 has been inserted!
*Sep 25 13:11:04.375: %SYS-6-CLOCKUPDATE: System clock has been updated from 13:11:04 UTC Thu Sep 25 2014 to 10:11:04 BRT Thu Sep 25 2014, configured from console by console.
*Sep 25 13:11:05.083: %SYS-2-MALLOCFAIL: Memory allocation of 135188 bytes failed from 0x239B5848, alignment 0
Pool: Processor  Free: 87196  Cause: Not enough free memory
Alternate Pool: None  Free: 0  Cause: No Alternate pool
 -Process= "Init", ipl= 0, pid= 3
-Traceback= 23B39078z 2568AB84z 239AE950z 239AEAE0z 2399DB90z 2399DCC8z 2399DD6Cz 2399DC20z 2399DD6Cz 2399DC20z 2399DD6Cz 2399EF78z 239ABEA8z 239B01DCz 2398A11Cz 239D1740z
*Sep 25 13:11:12.167: %IP-4-DUPADDR: Duplicate address 192.168.111.1 on GigabitEthernet0/1, sourced by 0026.5ac9.d371
*Sep 25 13:11:12.171: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1, changed state to up
*Sep 25 13:11:12.171: %LINEPROTO-5-UPDOWN: Line protocol on Interface NVI0, changed state to up
*Sep 25 13:11:12.171: %LINK-5-CHANGED: Interface Embedded-Service-Engine0/0, changed state to administratively down
*Sep 25 13:11:13.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface Embedded-Service-Engine0/0, changed state to down
No warm reboot Storage
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x28d3b53c
  PC = 0x21d33f7c, SP = 0x294ec528, RA = 0x21d322ac
  Cause Reg = 0x00000024, Status Reg = 0x50009fe3
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 256 MB
CISCO1905BR-SEC/K9 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC disabled
Readonly ROMMON initialized
program load complete, entry point: 0x80903000, size: 0x4c4a0
IOS Image Load Test
___________________
Digitally Signed Release Software
program load complete, entry point: 0x81000000, size: 0x41c1bd8
Self decompressing the image : #################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
                 TYPE      MEMORY_REQ
    Onboard devices &
         buffer pools      0x01E8F000
               TOTAL:      0x01E8F000
Rounded IOMEM up to: 32Mb.
Using 12 percent iomem. [32Mb/256Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M6a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 15-Apr-14 03:31 by prod_rel_team
export@cisco.com.
1 terminal line
 10:17:59 BRT Thu Sep 25 2014: Breakpoint exception, CPU signal 23, PC = 0x21D328FC
-Traceback= 0x21D2D07Cz 0x21D2B3ACz 0x23B39078z 0x2568AB84z 0x239AE950z 0x239AEAE0z 0x2398F2F8z 0x2399035Cz 0x23990640z 0x2398D904z 0x2398DA20z 0x2398E044z 0x2398BE28z 0x2399EFA4z 0x239ABEA8z 0x239B01DCz
a0 : 00000000 2A92E410, a1 : 00000000 00000001, a2 : 00000000 00000000, a3 : 00000000 00000000
t0 : 00000000 21DEDA9C, t1 : 00000000 50009FE1, t2 : 00000000 21018598, t3 : FFFFFFFF FFFF00FF
t4 : 00000000 21018598, t5 : 00000000 00000000, t6 : FFFFFFFF 80011800, t7 : 00000000 00000C28
s4 : 00000000 239B41C8, s5 : 00000000 00000000, s6 : 00000000 00000000, s7 : 00000000 00000000
gp : 00000000 287E0480, sp : 00000000 294D4B58, s8 : 00000000 294D4BC0, ra : 00000000 21D30C2C
EPC  : 21D328FC, ErrorEPC : 80412BEC, SREG     : 50009FE3
MDLO : 00000E02, MDHI     : 00000000, BadVaddr : 00000000
CacheErr_Icache : 0x007F7F00 - 00001EF8, CacheErr_Dcache : 0x00000000 - 00001190
TagLo_Icache : 0x00000000 - 2101FB83, DataLo_Icache : 0x8E34003C - 8C430000
TagLo_Dcache : 0x00000000 - 28152A83, TagHi_Dcache : 0x00000000 - 087D8681
DataLo_Dcache: 0x00000001 - 212D92D0, DataHi_Dcache : 0x00000000 - 00000013
TEXT_START : 0x21006158
DATA_START : 0x256A9880
File usbflash0:crashinfo_20140925-101759-BRT open failed (-1): No more root directory entries available
File usbflash0:crashinfo_20140925-101827-BRT open failed (-1): No more root directory entries available
2 RESPOSTAS
Bom dia Amigo, Veja se as
Bom dia Amigo,
Veja se as informações deste link podem te ajudar. Isso que voce relatou é um bug de alocação de memória. Mas pode ter outras causas raiz, como quantidade de memoria insuficiente, etc.
http://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/26145-crashes-swforced-troubleshoot.html
Attn
Daniel
Daniel Sobrinho
ale.moscarella, bom dia! A
A melhor maneira de resolver um problema de crash em seu roteador seria abrindo um caso com o TAC para que este crash seja analisado e identificado se é um problema de HW ou SW.
Além disto, uma outra opção seria fazer o upgrade do IOS para última versão e verificar se o problema ainda persiste ou não.
Atenciosamente,
Thiago Lopes
310
Apresentações
Útil
Respostas
CriarFaça o para criar o conteúdo
