cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Routing with access point
i have attached
2504 cisco wireless controler with cisco core switch and core switches is conneceted throuhg multiple access point and
internet connection is also terminated at wireless controller but the problem is that internet is not working at access point.
Navaz
Navaz
2 SOLUÇÕES ACEITES
Soluções aceites
Gold
Hi Navaz,
Not sure how you have connected internet directly to WLC. What sort of internet connectivity yu have got?
It would be difficult for some one to answer this question with out knowing the topology (how these devices are physically connected and configured). Will you be able to share the same?
Najaf
Gold
Hi Navaz,
Good to know that ping is fine.
Could you please share the complete output from WLC with "debug capwap events enable" and try removing the AP and connecting it back.
Also have you tried putting the AP on the same subnet of WLC and verified if it can register to WLC?
Najaf
12 RESPOSTAS
Gold
Hi Navaz,
Najaf
Re: Routing with access point
thanks for the reply
internet having satic ip is conecten with controller.
Navaz
Navaz
firewall ----> cisco core switch -------> wireless controller ------ switches ---- access point
this is the topolgy
Navaz
Navaz
Gold
Hi Navaz,
So far i not seen a setup where Internet link is directly connected to WLC. But looks like few people have tried this :-)
1) First question is whether internet is working fine when you terminate internet connection directly to an laptop?
2) Assuing that AP's are already registered with WLC whenter clients are getting ip address when connected to wireless network?
3) Have you setup guest wireless access on WLC?
4) How is your WLC interface configuration looking like?
5) Is the there any SSID configured on WLC to access production network?
Najaf
i got this error
"LAP 1142 N Ap configuration issue
Navaz
Navaz
Gold
Hi Navaz,
Where are you seeing this error? Does the WLC has any AP which is already registered to it? If you are seeing this on single AP please share the logs from AP console...
Najaf
*Mar  1 00:00:31.456: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar  1 00:00:31.495: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:00:32.457: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:00:32.457: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI initiated
*Mar  1 00:00:38.810: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:00:47.811: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER
*Mar  1 00:00:56.812: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Mar  1 00:01:07.815: %CAPWAP-3-ERRORLOG: Selected MWAR 'wuen4001'(index 0).
Navaz
Navaz
Gold
Hi Navaz,
Are you using DHCP of Static for ip address assignment for the AP?
From AP console try issueing this command.
capwap ap controller ip address <wlc-mgmt-ip>
Also verify if you are able to ping the controller managment ip address from AP console.
Najaf
I have already configured these setting on AP
debug capwap con cli
delete /force /recursive flash:/c1140-k9w8-mx.124-18a.JA2
You can also free free to remove the configuration files as well:
delete /force flash:private-multiple-fs
delete /force flash:lwapp_reap.cfg
Be sure to reload the LAP when complete. Once reloaded, the AP will boot the c1140-rcvk9w8-mx image, and then will allow for the static configuration commands:
lwapp ap ip address
lwapp ap controller ip address
lwapp ap hostname
lwapp ap ip default-gateway
BUT still same status WAPCAP error.
Navaz
Navaz
Gold
Sorry what CAPWAP error mesage are you getting? Where are you seeing this?
Have you checked if you are reachability from AP to WLC with a simple ping?
Najaf
yes, pinging successfully
Navaz
Gold
Hi Navaz,
Najaf
258
Apresentações
Kudo
12
Respostas
