cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Comunicados
Bem-vindo à Comunidade de Suporte da Cisco, gostaríamos de ter seus comentários.
Switch 3650 não inicia
Bom dia Amigos;
Tenho um WS-3650-24PS que não inicia, ele está apresentado essa essas mensagem:
Booting...Initializing RAM +++++++@@@@@@@@...++++++++++++++++++++++++++++++++
Base ethernet MAC Address: cc:46:d6:b8:ca:80
Interface GE 0 link down***ERROR: PHY link is down
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 2 seconds....done Initializing Flash.
Getting rest of image
Reading full image into memory....done
Reading full base package into memory...: done = 82657092
Bundle Image
Kernel Address : 0x6042d34c
Kernel Size : 0x418331/4293425
Initramfs Address : 0x60845680
Initramfs Size : 0xe780c1/15171777
Compression Format: .mzip
Bootable image at @ ram:0x6042d34c
Bootable image segment 0 address range [0x81100000, 0x82140000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x8166a500 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
Front-end Microcode IMG MGR: found 1 microcode images for 1 device.
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_8_1
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...83664 bytes.
Front-end Microcode IMG MGR: Programming device 0...
% Front-end Microcode IMG MGR: address 0, Could not enable sys_poll
% Front-end Microcode IMG MGR: unable to program device: 0
% Front-end Microcode IMG MGR: malformed microcode cache
Dec 9 13:23:05 %PLATFORM_MGR-1-PLATMGR_INIT_FAIL: Platform ManagDec 9 13:23:05 %IOSXE-2-PLATFORM: process ng_dumper: Process platform_mgr: terminated abnormally.
Dec 9 13:23:06 %IOSXE-2-PLATFORM: process platform_mgr: ===================== Exception Data ====================
Dec 9 13:23:06 %IOSXE-2-PLATFORM: process platform_mgr: Exception in 'platform_mgr' with Signal=SIGABRT(6)
Dec 9 13:23:06 %IOSXE-2-PLATFORM: process platform_mgr: Frame Pointer=0x7FD12E60, Program Counter=0x2BFA43B0
Dec 9 13:23:06 %IOSXE-2-PLATFORM: process platform_mgr: Thread ID=5896: -Traceback= 1#20db66b598bc323d48a7165b61f3c899 pthread:2BF92000+123B0
<Fri Dec 9 13:23:05 2016> Message from sysmgr: Reason Code:[2] Reset Reason:Service [platform_mgr] pid:[5896] terminated abnormally [6].
Details:
Service: platform_mgr
Description: 3K Platform Manager
Executable: /tmp/sw/mount/cat3k_caa-platform.SPA.03.06.03E.pkg//usr/binos/bin/platform_mgr
Started at Fri Dec 9 13:22:02 2016 (883147 us)
Stopped at Fri Dec 9 13:23:05 2016 (530892 us)
Uptime: 1 minutes 3 seconds
Start type: SRV_OPTION_RESTART_STATELESS (23)
Death reason: SYSMGR_DEATH_REASON_FAILURE_SIGNAL (2)
Last heartbeat 0.00 secs ago
PID: 5896
Exit code: signal 6
CWD: /var/sysmgr/work
PID: 5896
UUID: 3008
Switch rebooted continously for atleast 5 times. Disabling autoreboot
Unmounting ng3k filesystems...
Unmounted /dev/sda3...
Warning! - some ng3k filesystems may not have unmounted cleanly...
Please stand by while rebooting the system...
Restarting system.
Alguém já pegou esse tipo de erro?
Obrigado desde já
1 RESPOSTA
Matheus boa tarde,
Matheus boa tarde,
Percebi que foi quando vai colocar algum driver em algum chip, o "Microcode" da imagem, está corrompido, você precisa atualizar o IOS para o device funcionar corretamente.
PS: Marque a pergunta como respondida se sua consulta tiver sido respondida.
40
Apresentações
Kudo
Respostas
