em 05-26-2015 08:21 AM - última edição em 03-25-2019 11:26 PM por ciscomoderator
Good Morning !
On 23/05 performed a frame-relay multilink setup in a SONET (SPA-1XCHSTM1 / OC3) in a ASR 1006 IOS WITH asr1000rp1-advipservicesk9.03.10.05.S.153-3.S5-ext.bin;
When removing the shut down the router interface now presents errors below and only normalized after a physical reset.
Has anyone seen this error and could help me?
Error log:
May 23 02:12:20: %SYS-5-CONFIG_I: Configured from console by fernando on vty0 (10.98.22.202)
May 23 02:12:55: %CPPHA-3-FAULT: F0: cpp_ha: CPP:0 desc:CPP Client process failed: cpp_cp det:HA class:CLIENT_SW sev:FATAL id:1 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
May 23 02:12:55: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
May 23 02:12:56: %CPPOSLIB-3-ERROR_NOTIFY: F0: fman_fp_image: fman-fp encountered an error -Traceback= 1#6be92e2ad133c3ba9fa42246fd27ec35 errmsg:CAA7000+2250 cpp_common_os:A61F000+BB30 cpp_common_os:A61F000+B940 cpp_common_os:A61F000+18E2C cpp_mmon_lib:9B7F000+307C cpp_common_os:A61F000+10F38 cpp_common_os:A61F000+1104C evlib:AEF5000+E06C evlib:AEF5000+10454 :10000000+302FE4 c:8BAB000+1E938 c:8BAB000+1EAE0
May 23 02:12:56: %CPPDRV-3-LOCKDOWN: F0: fman_fp_image: CPP10(0) CPP Driver LOCKDOWN due to fatal error.
May 23 02:12:56: %PMAN-3-PROCHOLDDOWN: F0: pman.sh: The process cpp_ha_top_level_server has been helddown (rc 69)
May 23 02:12:56: %PMAN-3-PROCHOLDDOWN: F0: pman.sh: The process cpp_cp_svr has been helddown (rc 139)
May 23 02:13:07: %CPPHA-3-FAULT: F1: cpp_ha: CPP:0 desc:CPP Client process failed: FMAN-FP det:HA class:CLIENT_SW sev:FATAL id:1 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
May 23 02:13:07: %IOSXE-6-PLATFORM: F1: cpp_ha: Shutting down CPP MDM while client(s) still connected
May 23 02:13:07: %PMAN-3-PROCHOLDDOWN: F1: pman.sh: The process cpp_ha_top_level_server has been helddown (rc 69)
May 23 02:13:07: %PMAN-3-PROCHOLDDOWN: F1: pman.sh: The process fman_fp_image has been helddown (rc 134)
May 23 02:13:35: %SYS-5-CONFIG_I: Configured from console by fernando on vty0 (10.98.22.202)
May 23 02:14:07: %LINK-3-UPDOWN: Interface MFR109, changed state to down
May 23 02:16:48: %CPPHA-3-FAULT: F0: cpp_ha: CPP:0 desc:CPP Client process failed: FMAN-FP det:HA class:CLIENT_SW sev:FATAL id:1 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
May 23 02:16:48: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
May 23 02:16:48: %PMAN-3-PROCHOLDDOWN: F0: pman.sh: The process cpp_ha_top_level_server has been helddown (rc 69)
May 23 02:16:48: %PMAN-3-PROCHOLDDOWN: F0: pman.sh: The process fman_fp_image has been helddown (rc 134)
May 23 02:16:51: %CPPDRV-3-LOCKDOWN: F0: cpp_cp: CPP10(0) CPP Driver LOCKDOWN due to fatal error.
May 23 02:17:05: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F1
Configuration applied:
controller SONET 2/0/0
au-4 1 tug-3 1
tug-2 1 e1 3 description # < KLM 113 >
tug-2 2 e1 2 description #< KLM 122 >
interface Serial2/0/0.1/1/1/3:0
description
bandwidth 2048
no ip address
encapsulation frame-relay MFR109
no arp frame-relay
NO SHUT
interface Serial2/0/0.1/1/2/2:0
description
bandwidth 2048
no ip address
no arp frame-relay
NO SHUT
interface MFR109
description
ip vrf forwarding xxxxx
ip address xx.xx.xx.xx 255.255.255.252
frame-relay interface-dlci 232
class 3891/PVB/XXX-4V
frame-relay intf-type dce
shut
router rip
no passive-interface MFR109
em 09-14-2015 10:59 AM
Olá, Fernando. Tudo bem?
Como foi gerada uma mensagem de traceback, o mais recomendado neste caso seria abrir um caso com o TAC para que o engenheiro possa fazer o decode da mensagem e pesquisar a root cause do problema.
Atenciosamente.
Caio Mello
Navegue pelos links rápidos da Comunidade e usufrua de um conteúdo personalizado e em seu idioma nativo:
