cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Configurar Aironet 1700 AIR-CAP1702I-A-K9
No puedo configurar...
Me pueden ayudar..
Mar  1 00:25:32.607: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP ad
dress is not assigned or assigned IP is wrong. Renewing DHCP IP.
IOS Bootloader - Starting system.
flash is writable
Antigua Lite Board P2
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 239 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 20173824
flashfs[0]: Bytes available: 20984832
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 00:35:1a:78:af:98
Ethernet speed is 100 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entr
y point: 0x2003000
executing...
Secondary Bootloader - Starting system.
40MB format
flashfs[0]: flashfs fsck took 11 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot  flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...###########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entr
y point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JC, RELEASE
 SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 11-Dec-15 11:55 by prod_rel_team
40MB format
Initializing flashfs...
flashfs[2]: 239 files, 8 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 20173824
flashfs[2]: Bytes available: 20726784
flashfs[2]: flashfs fsck took 11 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 1 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco AIR-CAP1702I-A-K9 (PowerPC) processor (revision A0) with 376814K/134656K b
ytes of memory.
Processor board ID FCW2005N82Z
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.2.100.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: XX:XX:XX:XX:XX:XX
Part Number                          : XXXX
PCB Serial Number                    : XXXXX
Top Assembly Part Number             : XXXXXX
Top Assembly Serial Number           : XXXXXX
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1702I-A-K9
% Please define a domain-name first.
ipv6 enable
% Invalid input detected at '^' marker.
ipv6 address autoconfig
ipv6 address dhcp
Press RETURN to get started!
*Mar  1 00:00:13.475: APAVC: Initial WLAN Buffers Given to System is  2500
*Mar  1 00:00:13.523: APAVC:  WlanPAKs 42878 RadioPaks  42270
*Mar  1 00:00:13.523: Starting Ethernet promiscuous mode
*Mar  1 00:00:13.527: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config f
ailed, trying backup...
*Mar  1 00:00:13.527: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak conf
ig failed...
*Mar  1 00:00:14.831: %LWAPP-4-CLIENTEVENTLOG: PnP waiting for capwap init
*Mar  1 00:00:15.503: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state
to up
*Mar  1 00:00:15.567: %SYS-5-RESTART: System restarted --
 SOFTWARE (fc1)
*Mar  1 00:00:15.567: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a c
old start
*Mar  1 00:00:15.607: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state
to up
*Mar  1 00:00:15.611: %CDP_PD-4-POWER_OK: Full power - HIGH_POWER inline power s
ource
*Mar  1 00:00:15.619: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config f
*Mar  1 00:00:15.619: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak conf
ig failed...
*Mar  1 00:00:15.619: spamInitRadCfg: recovery image default mode 0
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:15.787: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:16.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar  1 00:00:17.611: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state
 to administratively down
*Mar  1 00:00:20.399: DPAA Initialization Complete
*Mar  1 00:00:20.399: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exite
d
*Mar  1 00:00:27.607: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:00:28.607: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to down
bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact pe
rformance
*Mar  1 00:00:34.531: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg config f
*Mar  1 00:00:34.531: %LWAPP-3-CLIENTERRORLOG: Load nvram:/lwapp_ap.cfg.bak conf
ig failed...
*Mar  1 00:00:34.531: %CAPWAP-3-EVENTLOG: No Config Present. PNP required
*Mar  1 00:00:34.535: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
Not in Bound state.
*Mar  1 00:01:22.563: %LWAPP-4-CLIENTEVENTLOG: Invoking capwap discovery
Etiquetas (1)
80
Visitas
ÚTIL
Respuestas
