cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Configurar Cisco 887 detrás de router fibra ONO
Buenas tardes a todos,
Llevo 2 dias intentando configurar un Cisco 887 detrás de un router de fibra de Ono y no hay manera. El caso es que Vodafone Ono (Empresas), nos ha colocado su router en modo bridge y nosotros, hemos configurado un puerto FE como WAN asociado a la VLAN10.
Pongo la configuración que hemos usado a ver si alguién me puede echar una mano:
! Last configuration change at 11:16:55 ESPANA Thu Dec 17 2015
version 15.2
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone ESPANA 1 0
clock summer-time ESPANA recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip source-route
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 10.12.9.1 10.12.9.199
ip dhcp excluded-address 10.12.9.250 10.12.9.254
ip dhcp pool POOLDHCP
network 10.12.9.0 255.255.255.0
default-router 10.12.9.251
dns-server 62.81.29.254 62.81.16.213
lease 0 1
no ip bootp server
no ip domain lookup
ip cef
ip name-server 62.81.29.254
ip name-server 62.81.16.213
no ipv6 cef
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
license udi pid C887VAG+7-K9 sn FCZ1705C1FS
controller VDSL 0
controller Cellular 0
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
lifetime 3600
crypto isakmp key <key> address x.x.x.x
crypto map xxxxx 10 ipsec-isakmp
set peer x.x.x.x
match address acl_vpn
interface Ethernet0
no ip address
shutdown
interface ATM0
no ip address
shutdown
interface FastEthernet0
description CONNECTED TO WAN
switchport access vlan 10
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip address 10.12.9.251 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
no ip virtual-reassembly in
ip policy route-map clear-df
load-interval 30
no autostate
arp timeout 86400
interface Vlan10
ip address dhcp
ip nat outside
crypto map xxxx
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static tcp 10.12.9.100 83 interface Vlan10 83
ip nat inside source static tcp 10.12.9.100 10000 interface Vlan10 10000
ip nat inside source static tcp 10.12.9.91 81 interface Vlan10 81
ip nat inside source static tcp 10.12.9.91 6036 interface Vlan10 6036
ip nat inside source route-map MAP-LINEA-PPAL interface Vlan10 overload
ip route 0.0.0.0 0.0.0.0 81.184.3.33
ip access-list extended acl_lan_wan
deny ip 10.12.9.0 0.0.0.255 10.1.0.0 0.0.255.255
permit ip 10.12.9.0 0.0.0.255 any
ip access-list extended acl_vpn
permit ip 10.12.9.0 0.0.0.255 10.1.0.0 0.0.255.255
route-map MAP-LINEA-PPAL permit 10
match ip address acl_lan_wan
match interface Vlan10
Lógicamente, tampoco me funciona la IPSec...gracias anticipadas!
1 RESPUESTA
hola, puedes regalar la
hola, puedes regalar la salida del comando *sh vlan-sw* en el router?
147
Visitas
ÚTIL
Respuestas
