cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Configure mls qos map dscp-cos **** on Switch 2960
I need to configure mls qos map dscp-cos ******
But not appear mls qos map
Switch(config)#mls qos ?
  rewrite    Rewrite Packet/Frame
  srr-queue  Configure SRR receive queues
  <cr>
Which is the reason?
cisco WS-C2960-24LC-S
c2960-lanlitek9-mz.122-53.SE2.bin
Guillermo
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hi Guillermo,
Hi Guillermo,
   The reason for this behavior is because you are using the Lan lite feature set for your switch. You need LAN Base feature set to support QoS Map Tables. The following indicates this as well as other features not available for your current image:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swqos.html
Regards.
1 RESPUESTA
Hi Guillermo,
Hi Guillermo,
Regards.
49
Visitas
ÚTIL
Respuestas
CrearPor favor para crear contenido
