cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Community Member
Diferencias entre los SW WS-C3850-24T-L y WS-C3850-24T-S
Buen día a todos los amigos de la comunidad..
1. La consulta es que diferencias existen entre estos modelos -L(Lan Base) y -S(Ip Base)?
2. Cual de esto Modelos Aceptan algun tipo de enrutamiento. ?
3. Como detecto que estos Sw son Administrables.. ?
4. Como detecto que son de Capa 2 o Capa 3
Agadeciendoles por su respuesta me despido
Saludos
DTB
2 RESPUESTAS
Hall of Fame Super Gold
"-L" = LAN Base
"-S" = IP Base
Either which way, it's Layer 2 until you upgrade the licenses on the hardware to "IP Services" and only then do you get full Layer 3.
With IP Base, you can do RIPv1, RIPv2, IS-IS, and some limited OSPF ...
Community Member
Buenas Carlos,
La diferencia entre los 2 modelos seria los features que soporta cada switch.
Features
The Catalyst 3850 switch supports three different feature sets:
LAN  Base feature set—Provides basic Layer 2+ features, including access  control lists (ACLs) and quality of service (QoS) and up to 4094 VLANs.
IP  Base feature set—Provides Layer 2+ and basic Layer 3 features  (enterprise-class intelligent services). These features include access  control lists (ACLs), quality of service (QoS), ACLs, QoS, static  routing, EIGRP stub routing, PIM stub routing, Routing Information  Protocol (RIP), basic IPv6 management, and support for Wireless  Controller functionality.
IP  Services feature set—Provides a richer set of enterprise-class  intelligent services and full IPv6 support. It includes all IP Base  features plus full Layer 3 routing (IP unicast routing, IP multicast  routing, and fallback bridging). The IP Services feature set includes  protocols such as the Enhanced Interior Gateway Routing Protocol (EIGRP)  and the Open Shortest Path First (OSPF) Protocol and support for  wireless controller functionality.
Los 2 modelos soportan enrutamiento a nivel de L3, como seria el intervlan routing, el WS-C3850-24T-S soporta por la imagen que tiene protocoles de enrutamiento.
Puedes aclara mas que se refiere con Administrables y con respecto a la ultima pregunta por defecto son switches capa 3 solo que depende de la imagen que esten usando van a poder hacer cosas mas complejas o no.
Saludos
Andres Larios
Recuerda calificar todas las respuestas, es tan importante como un gracias.
518
Visitas
ÚTIL
Respuestas
CrearPor favor para crear contenido
