cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Avisos
¡Bienvenido a la nueva Comunidad de Soporte de Cisco! Nos encantaría conocer su opinión
Help with Nat NVI0
Please inform me on how to get NVI0 up... NAT is enabled and nvi0 is still administratively down
SPFORT-RTR-881>en
Password:
SPFORT-RTR-881#sh ip int
FastEthernet0 is up, line protocol is down
  Internet protocol processing disabled
FastEthernet1 is up, line protocol is down
FastEthernet2 is up, line protocol is down
FastEthernet3 is up, line protocol is down
FastEthernet4 is up, line protocol is down
  Internet address is 208.83.93.154/30
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Virtual Fragment Reassembly, IPSec input classification, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside,
MCI Check
  Output features: CCE Output Classification, Post-routing NAT Outside, Post-routing NAT NVI Output, Stateful Inspection, IPSec output classification, IPSec: to
crypto engine, Post-encryption output features
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
NVI0 is administratively down, line protocol is down
  Interface is unnumbered. Using address of FastEthernet4 (208.83.93.154)
  MTU is 1514 bytes
  IP fast switching is disabled
  IP CEF switching is disabled
  IP Null turbo vector
  IP multicast fast switching is disabled
  Network address translation is disabled
  Input features: MCI Check
  Output features: Post-routing NAT NVI Output
Tunnel100 is up, line protocol is down
  Internet address is 10.250.250.1/30
  MTU is 1400 bytes
  Multicast reserved groups joined: 224.0.0.1 224.0.0.2 224.0.0.22 224.0.0.13
Tunnel101 is up, line protocol is down
  Internet address is 10.251.251.1/30
  MTU is 1400 bytes
Tunnel110 is up, line protocol is down
  Internet address is 10.250.250.5/30
  MTU is 1400 bytes
Tunnel111 is up, line protocol is down
  Internet address is 10.251.251.5/30
  MTU is 1400 bytes
Tunnel120 is up, line protocol is down
  Internet address is 10.250.250.9/30
  MTU is 1400 bytes
Tunnel121 is up, line protocol is down
  Internet address is 10.251.251.9/30
  MTU is 1400 bytes
Vlan1 is up, line protocol is down
  Internet address is 172.16.1.190/26
  MTU is 1500 bytes
  Network address translation is enabled, interface in domain inside
  Input features: Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
  Output features: NAT Inside, Stateful Inspection
Vlan10 is up, line protocol is down
thanks for the help in advance... been stuck on this for a while
5 RESPUESTAS
Help with Nat NVI0
Hello Blake.
Can you share your NAT configuration? NVI0 interface is meant for the "nat enable" feature so if you are
using static NAT or PAT NVI0 will appear down.
Re: Help with Nat NVI0
        The Router that this config is running on shows the NVI0 up/up. Im trying to config a clone to have as a backup. I copied the config from the router that is in service, but cannot get the NVI0 up.
SPFORT-RTR-881#sh ip nat statistics
Total active translations: 2 (2 static, 0 dynamic; 2 extended)
Peak translations: 2, occurred 16:12:42 ago
Outside interfaces:
  FastEthernet4, Vlan10
Inside interfaces:
  Tunnel10, Vlan1
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] route-map ISP1 interface FastEthernet4 refcount 0
[Id: 2] route-map ISP2 interface Vlan10 refcount 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
SPFORT-RTR-881#
Help with Nat NVI0
Blake,
Unless you use the "ip nat enable" command, the NVI interface will not come up. Your normal NAT/PAT will work just fine and this is not something you need to worry about. I am not sure I can explain at this time why one router has the NVI up/up and not the other but I am sure NAT will work on your clone.
Here is some further information about NVI and when it should be used:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/12-4t/nat-12-4t-book/iadnat-addr-consv.html#GUID-E7293F63-C812-4C67-A086-1991E50F21FF
If you are able to share your configs, we can probably dive a little deeper into this.
here is the entire config
SPFORT-RTR-881#sh run
Building configuration...
Current configuration : 6949 bytes
version 12.4
no service pad
service password-encryption
hostname SPFORT-RTR-881
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password
no aaa new-model
memory-size iomem 10
clock timezone CST -6
clock summer-time CDT recurring
ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.1.129 172.16.1.184
ip dhcp excluded-address 172.16.1.188 172.16.1.190
ip dhcp pool myPool
   import all
   network 172.16.1.128 255.255.255.192
   default-router 172.16.1.190
   dns-server 4.2.2.2
ip cef
no ip domain lookup
ip multicast-routing
no ipv6 cef
crypto isakmp policy 1
encr aes 256
authentication pre-share
group 5
crypto isakmp key address 74.113.93.114
crypto isakmp key  address 74.113.89.171
crypto isakmp key address 74.113.91.2
crypto isakmp key  address 65.15.201.19
crypto isakmp key address 199.72.150.130
crypto ipsec transform-set secure_transform esp-aes 256 esp-sha-hmac
crypto map MASTER_CRYPTO_MAP 10 ipsec-isakmp
set peer 74.113.93.114
set transform-set secure_transform
match address to_Mobile
crypto map MASTER_CRYPTO_MAP 20 ipsec-isakmp
set peer 74.113.89.171
match address to_HEI
crypto map MASTER_CRYPTO_MAP 30 ipsec-isakmp
set peer 74.113.91.2
match address to_Calvert
crypto map MASTER_CRYPTO_MAP 40 ipsec-isakmp
set peer 65.15.201.19
match address to_OceanSprings
crypto map MASTER_CRYPTO_MAP 50 ipsec-isakmp
set peer 199.72.150.130
match address to_TK
archive
log config
  logging enable
  hidekeys
path ftp://192.168.0.29/SpanishFort-881
write-memory
ip ftp source-interface Vlan1
ip ftp username HEI
ip ftp password
track 10 ip sla 1 reachability
delay down 1 up 1
track 20 ip sla 2 reachability
delay down 1 up 1
interface Tunnel10
no ip address
ip nat inside
ip nat enable
ip virtual-reassembly
interface Tunnel100
description ***Tunnel_To_Mobile***
ip address 10.250.250.1 255.255.255.252
ip mtu 1400
ip pim version 1
ip pim sparse-dense-mode
tunnel source FastEthernet4
tunnel destination 74.113.93.114
interface Tunnel101
description ***Tunnel_To_Mobile_Backup***
ip address 10.251.251.1 255.255.255.252
ip mtu 1400
ip pim version 1
tunnel source Vlan10
interface Tunnel110
description ***Tunnel_To_Calvert***
ip address 10.250.250.5 255.255.255.252
ip mtu 1400
ip pim version 1
tunnel destination 74.113.91.2
interface Tunnel111
description ***Tunnel_To_Calvert_Backup***
ip address 10.251.251.5 255.255.255.252
ip mtu 1400
ip pim version 1
interface Tunnel120
description ***Tunnel_To_OceanSprings***
ip address 10.250.250.9 255.255.255.252
ip mtu 1400
ip pim version 1
tunnel destination 65.15.201.19
interface Tunnel121
description ***Tunnel_To_OceanSprings_Backup***
ip address 10.251.251.9 255.255.255.252
ip mtu 1400
ip pim version 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 10
description ***Outside***
ip address 208.83.93.154 255.255.255.252
ip nat outside
ip nat enable
duplex auto
speed auto
interface Vlan1
description ***Inside***
ip address 172.16.1.190 255.255.255.192
ip pim version 1
ip nat inside
ip nat enable
ip igmp join-group 225.8.11.81
interface Vlan10
description To_Verizon_4G
ip dhcp client client-id FastEthernet3
ip address dhcp
ip nat outside
ip nat enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 208.83.93.153 track 10
ip route 0.0.0.0 0.0.0.0 166.150.80.5 track 20
ip route 172.16.1.0 255.255.255.192 Tunnel110
ip route 172.16.1.0 255.255.255.192 Tunnel111 10
ip route 172.16.1.64 255.255.255.192 Tunnel100
ip route 172.16.1.64 255.255.255.192 Tunnel101 10
ip route 172.16.1.192 255.255.255.192 Tunnel120
ip route 172.16.1.192 255.255.255.192 Tunnel121 10
no ip http server
no ip http secure-server
ip pim bidir-enable
ip pim rp-address 172.16.1.126
ip nat inside source route-map ISP1 interface FastEthernet4 overload
ip nat inside source route-map ISP2 interface Vlan10 overload
ip nat inside source static udp 172.16.1.184 5198 208.83.93.154 5198 extendable
ip nat inside source static udp 172.16.1.184 5199 208.83.93.154 5199 extendable
ip access-list extended acl_nat
deny   ip 172.16.1.128 0.0.0.63 172.16.1.0 0.0.0.63
deny   ip 172.16.1.128 0.0.0.63 172.16.1.64 0.0.0.63
deny   ip 172.16.1.128 0.0.0.63 172.16.1.192 0.0.0.63
deny   ip 172.16.1.128 0.0.0.63 172.16.2.0 0.0.0.63
deny   ip 172.16.1.128 0.0.0.63 192.168.0.0 0.0.0.255
permit ip 172.16.1.128 0.0.0.63 any
ip access-list extended to_Calvert
permit gre host 208.83.93.154 host 74.113.91.2
permit gre host 166.150.80.6 host 74.113.91.2
ip access-list extended to_HEI
permit ip 172.16.1.128 0.0.0.63 192.168.0.0 0.0.0.255
ip access-list extended to_Mobile
permit gre host 208.83.93.154 host 74.113.93.114
permit gre host 166.150.80.6 host 74.113.93.114
ip access-list extended to_OceanSprings
permit gre host 208.83.93.154 host 65.15.201.19
permit gre host 166.150.80.6 host 65.15.201.19
ip access-list extended to_TK
permit ip 172.16.1.128 0.0.0.63 172.16.2.0 0.0.0.63
ip sla 1
icmp-echo 208.83.93.153
timeout 500
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 198.224.156.135
timeout 500
frequency 1
ip sla schedule 2 life forever start-time now
snmp-server community HEIc0mStr8ng RO
snmp-server trap-source Vlan1
snmp-server location SpanishFort
snmp-server contact Dial HEI Support at # 434-4000
snmp-server enable traps tty
snmp-server enable traps envmon
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec tunnel stop
snmp-server host 192.168.0.29 version 2c HEIc0mStr8ng
route-map ISP2 permit 10
match ip address acl_nat
match interface Vlan10
route-map ISP1 permit 10
match interface FastEthernet4
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password
login
scheduler max-task-time 5000
ntp source Vlan1
ntp update-calendar
ntp server 192.168.0.2
end
Thank you Blake.
I am confirming you are using normal NAT based on your configuration therefore, the "ip nat enable" commands in tunnel10, FastEthernet4, int vlan 1 and int vlan 10 is not needed. In some IOS versions, sometimes you enable "ip nat outside" or "ip nat inside" and this for some reason brings up the NVI interface but it does not get used for translations at all.
If your router is in production, you can schedule a maintenance window to remove the "ip nat enable" command to confirm is not needed and your translations will still function.
3316
Visitas
ÚTIL
Respuestas
CrearPor favor para crear contenido
