Access list help for FTP
whiteford
My access list on my Cisco 877 ADSL router seems to be blocking part of the the ftp process.
When connected to this router I can get out to the internet a get web pages etc and if I connect to an ftp server I get the logon and password screen and it authenticate me then times out and shows no folders. If I take the access list off the dialer interface it all workds.
Here are the deny logs I see from the terminal monitor, they are my 3 attempts:
list 101 denied tcp 1.2.3.72(4580) -> 1.2.4.79(1201), 1 packet
list 101 denied tcp 1.2.3.72(4584) -> 1.2.4.79(1205), 1 packet
list 101 denied tcp 1.2.3.72(4563) -> 1.2.4.79(1153), 2 packets
Config:
interface Dialer1
Ip access-group 101 in
access-list 101 permit udp any eq domain any
access-list 101 permit tcp any eq www any
access-list 101 permit tcp any eq 443 any
access-list 101 permit tcp any eq ftp any
access-list 101 permit tcp any eq 5800 any log
access-list 101 permit tcp any eq 5900 any log
access-list 101 permit tcp any eq 8080 any log
access-list 101 permit udp any eq isakmp any
access-list 101 permit udp any eq non500-isakmp any
access-list 101 deny ip any any log
tcordier
I suggest you add the line
access-list 101 permit tcp any eq ftp-data any
to allow the ftp data flow also. After succesful authentication, the ftp server will send data on port 20 (not 21). If the data flow is not permitted also, you will be unable to browse the folders. See e.g. http://www.slacksite.com/other/ftp.html
HTH, Thomas
I added that and I got the same deny errors as before.
Hmmm.. are you using passive ftp?
Try adding the keyword "established" to your entry in the accesslist entry for ftp. If you are using passive ftp, the access list needs to change to include high ports. See this link for configuration examples: http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080100548.shtml
HTH, Thomas
