ASA Translation Table
itdsmartnet
hi,
i have done PAT and STATIC(dmz,outside) a.b.c.d 10.5.0.5 translation in my ASA. when i Change Static (DMZ,outside)w.x.y.z 10.5.0.0 translation, is it possible to clear translation table.
8 Replies 8
mohsin.khan
Level 3
Level 3
If you change the NAT configuration, and you do not want to wait for existing translations to time out before the new NAT information is used, you can clear the translation table using the clear xlate command. However, clearing the translation table disconnects all current connections that use
translations, and then starts building new connections based on new configuration.
regards,
Mohsin
hi,
what if i change static translation, do i need clear xlate then
Practically, you don't need to clear xlate on changing static translation. However, you can use "show static" command to see which public ip is statically natted to your private IP.
Mohsin
hi,
i have a problem , i have two public ip's , i have static (dmz,outside) xx.xx.xx.9 10.5.0.5
access-list webserver extended permit tcp any host xx.xx.xx.9 eq ftp
access-group webserver in interface outside
this works fine but when i use static(dmz,outsidt) xx.xx.xx.12 10.5.0.5 for the same server , it will not. what might be the problem
thanks
Please be specific. it will not what?
There are 2-3 points that you must remember,
- You can assign 2 public IPs to a single private IP, but that is not recommended.
- Your ACL for ftp is for XX.XX.XX.9 only, if you want to use ftp for 2nd public IP also, you need to add another ACL,i.e
However, ACLs work in sequential way, so all the incoming traffic will hit the first ACL of XX.XX.XX.9 and hence 2nd ACL will be useless. But in case you want to serve ftp on XX.XX.XX.9 and http on XX.XX.XX.12 for same privae ip 10.5.0.5, then you can add
access-list webserver extended permit tcp any host xx.xx.xx.12 eq http
along with xx.xx.xx.9 eq ftp command...
But, why would you like to have 2 public IPs for 1 private IP?
hi,
i told when i use static (dmz, outside) xx.xx.xx.9 10.5.0.5
this works fine but when i remove the above static mapping and re-create static mapping with xx.xx.xx.12 with ACL change to xx.xx.xx.12 for ftp it is not working.
well, in that case you need to check using show static and sh xlate | in xx.xx.xx.12 that fw/asa has updates its xlation table. If not, then try to clear xlate and then check the same.
when u get this problem after changing nat lines just reload the firewall
