Cisco 2651xm/cable modem problem
timbroadaway
I have cox high speed internet and want to start using a Cisco 2651xm router instead of my small appliance router. Here is my basic config:
cable modem -f0/1 port of 2651xm - f0/0 port into small netgear swtich - pc into netgear switch. (the 2651xm has two fastethernet ports)
I have set the f0/1 port to dhcp. It grabs an IP address from ISP from cable modem. I set the f0/0 port to static IP of 192.168.1.254. Pc is set to IP of 192.168.1.2.
I set up RIP routing in the router for network 70.0.0.0 and network 192.168.1.0. (The IP I get from my ISP is in the 70.0.0.0 range.
I can ping both interfaces of the router from my pc, but I cannot ping any address beyond the f0/1 port (any internet addresses). While I am consoled into my router I am able to ping any internet address, so the router is able to communicate w/ the outside world, it is just not passing any requests from my pc to the outside world.
I do not have any acl's setup. I have talked to a friend of mine that works w/ cisco routers alot and he said that he had tried the exact same setup and ran into the same problem. He mentioned that it might be an encapsulation problem. any ideas?
Here is my config:
hostname BCSRTR03
boot-start-marker
boot system flash:c2600-a3js-mz.123-11.T.bin
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address dhcp
duplex auto
speed auto
router rip
network 70.0.0.0
network 192.168.1.0
ip classless
ip http server
control-plane
gateway
timer receive-rtp 1200
line con 0
line aux 0
line vty 0 4
login
end
Here is my routing table:
Gateway of last resort is 70.186.123.1 to network 0.0.0.0
70.0.0.0/24 is subnetted, 1 subnets
C 70.186.123.0 is directly connected, FastEthernet0/1
172.19.0.0/32 is subnetted, 1 subnets
S 172.19.25.22 [254/0] via 70.186.123.1, FastEthernet0/1
C 192.168.1.0/24 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 [254/0] via 70.186.123.1
stschmidt
You will need to use network address translation on the router to translate the private range internally to the public IP externally. You will need to make sure your image can run nat.
http://www.cisco.com/en/US/customer/tech/tk648/tk361/tk438/tsd_technology_support_sub-protocol_home.html
Sample config is located here:
Substitute fa0/1 for the serial0 interface in the config.
Hope this helps.
stschmidt
Hope this helps.
Thank you very much. I had put the NAT statements in after my initial post and it still didn't work, but after I created an ACL of (access-list 102 permit ip 192.168.1.0 0.0.0.255 any) and applied it to the external interface, that did it for me. Thanks again for your help!
