09-13-2010 01:03 AM - edited 03-04-2019 09:45 AM
Hi All,
I have an CISCO2811-SRST/K9 ordered , but will need to know if it has a firewall with this bundle.
I will need to setup a VPN from this device to a head office and runn a Call Manager SIP trunk over the VPN.
Thanks very much for any help
Alalli
Solved! Go to Solution.
09-13-2010 01:54 AM
This is just a voice bundle and you will get basic Cisco IOS security feature set.
You need to opt for C2811-VSEC/K9 if you want both voice and security.
Pls refer the following link...
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd804e773d.html
Regards...
-Ashok.
09-13-2010 01:54 AM
Regards...
-Ashok.
09-13-2010 04:04 AM
09-13-2010 10:09 PM
Hi Amanda,
Please find the following link (CCO login required) to check about supported security features. This is Cisco tool (Feature Navigator) which gives you to look the supported features in detail.
tools.cisco.com/ITDIT/ISTMAIN/servlet/index
And, pls check the following link to get an idea about the differences between Cisco IOS releases.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps5460/prod_bulletin09186a00801af451.html
Regards...
-Ashok.
