10-24-2007 11:18 AM - edited 03-03-2019 07:19 PM
Dear Mister
I have two WAEs , in both sites . We don't use a Central Manager for this .
The customer has a Local Application , in the port 5000 ( the same of the Yahoo-Messenger ) .
I remove this configuration , and create another por this application .
How can I see , by cli , how is functioning the optimization . What is the meaning of this :
show statistics tfo
Total number of optimized connections : 3752
No. of active connections : 97
No. of pending (to be accepted) connections : 0
No. of connections closed normally : 3042
No. of connections closed with error : 613
Total number of peers : 1
No. of entries into overload mode : 0
No. of connections reset due to -
Socket write failure : 59
Socket read failure : 0
Opt socket close while waiting to write : 0
Unopt socket close while waiting to write : 19
Opt socket error close while waiting to read : 291
Unopt socket error close while waiting to read : 1
DRE decode failure : 0
DRE encode failure : 0
Connection init failure : 0
Opt socket unexpected close while waiting to read : 0
Exceeded maximum number of supported connections : 0
Buffer allocation or manipulation failed : 0
Peer received reset from end host : 243
DRE connection state out of sync : 0
Memory allocation failed for buffer heads : 0
Unoptimized data received at optimized socket : 0
Best Regards
10-30-2007 01:45 PM
To display Traffic Flow Optimization (TFO) statistics for a WAE, use the show statistics tfo EXEC command.
show statistics tfo [application app-name | pass-through | peer | saving app-name]
Syntax Description
application (Optional) Displays statistics per application.
app-name Application name.
pass-through (Optional) Displays the pass-through statistics.
peer (Optional) Displays peer information.
saving (Optional) Displays savings for all applications.
