firewalling and nat between ethernet subinterfaces on 1700?
hpoel
I'd like to use a 1721 router as a 'one-armed' firewall, i.e. routing and firewalling between vlan's on the FE interface of the router. Do the subinterfaces behave any different than physical interfaces for this purpose?
pkhatri
Level 11
Level 11
There is no problem with what you are suggesting. You can use the 1721 for inter-vlan routing. You can then applies access-lists on the ethernet sub-interfaces to filter traffic between the VLANs.
In terms of routing capabilities, you can do anything on ethernet sub-interfaces that you can do on physical ethernet interfaces.
Hope that helps - pls rate the post if it does.
Paresh
pkhatri
Level 11
Level 11
Paresh
