04-24-2010 04:50 AM - edited 03-04-2019 08:16 AM
High utilization on the router interface facing the internet,MRTG shows bandwidth fully utilized
this could be attack or server malfunctioning. how to restrict the bandwidth for incoming and outgoing traffic
how to identify which internal resource utilizing how much bandwidth
04-24-2010 10:56 AM
Hi Mathew ,
I will be good if you could share some output pointing towards high cpu.Is the high cpu due to process or interrupts.
Show process cpu will be helpful.
Vishwa
04-24-2010 11:07 AM
CPU utilization is less than 20%
04-26-2010 04:20 AM
Best tool to use to identify bandwidth utilization and hosts involved is NetFlow. You can gather some stats directly from the router but it is best to actually use a NetFlow collector of some type. See your IOS docs on configuring NetFlow.
04-26-2010 10:31 AM
There are couple of options available depending on your location.
Possible action at the moment
This will bring some smile to progress.
With regards,
Shailesh
