Inverse ARP doesn't work
kondratev
Hello!
I have 2 routers connected through the Frame Relay switch. On the first router (R1) I'd like to use static DLCI-IP mapping, but on the second (R2) I'd like to use Inverse ARP. Inverse ARP doesn't work. Output of 'show frame-relay map' is empty.
I've attached the scheme and parts of configs.
Could you please help me find the issue?
8 Replies 8
paolo bevilacqua
Why don't you use point-to-point subinterfaces instead and so eliminate all needs for confusing and obsolete configurations.
Unfortunately (there is a weighty reason) I must use multipoint interfaces.
And what would be the weigthy reason ?
Probably not heavvier than having unrealible, obscure rotuer configuration.
Giuseppe Larosa
Hello Kondratev,
inverse ARP works based on the fact the the remote DTE (R1 in your case) cooperates by sending frames that travel on the PVC telling "Hi at the other side of this PVC there is my interface and my address is x.x.x.x".
Now, you have only two DTE on a point-to-point PVC. On R1 you have configured the interface with:
frame-relay map ip 155.1.12.2 132
no frame-relay inverse-arp
the second command does not tell R1 to ignore inverse ARP messages coming from R2 but tells R1 to suppress its own messages.
As a result of this R2 is waiting for inverse ARP messages that will never come.
To be noted the FR switch has no role in this: its job ends when it switches FR frames from one port to the other port it does not take part in inverse ARP process.
So if you want to build a working example of inverse ARP you need to have it enabled on both DTE at the two ends of the PVC or move the frame-relay map command on R2 side
see
http://www.cisco.com/en/US/docs/ios/wan/command/reference/wan_f1.html#wp1015390
Hope to help
Giuseppe
OK. I've enabled Inverse ARP on R1. Here is the new config of R1. But R2 hasn't IP-to-DLCI mapping anyway.
Hello Kondratev,
post a sh frame-relay map taken on R2 in the new scenario.
you may want to consider to use point to multipoint subinterfaces
Hope to help
Giuseppe
sh frame-relay map taken on R2 is still empty.
Hello Kondratev,
I would try to use frame-relay route on the FR switch, I've never used the connect command.
With frame relay route you give two commands one under serial1 and one under serial2
int ser1
enc frame-rel
frame-rel intf-type dce
frame-relay route 132 int ser2 231
int ser2
enc frame-rel
frame-relay route 231 int ser1 132
this is the kind of FR switch I've used in the past
Hope to help
Giuseppe
