09-14-2009 09:47 AM - last edited on 03-25-2019 03:26 PM by ciscomoderator
What does the error when you display power-on diagnostics mean when it says:
M4:Non-Volatile Memory Read/Write Test []
*** MEMDIAG_NVRAM_MAGIC_PATTERN_DATA_ERROR *** [Addr:BE001008, exp:0000ABCD, act:00000000]
power-on Diagnostics Passed.
This is on a L1010 with FCPFQ and no config on it.
09-14-2009 10:38 AM
Hello Brian,
the device has failed a memory test, however the overall result is passed.
Depending on the use you can ignore this if it is for a lab for example.
Hope to help
Giuseppe
09-14-2009 10:39 AM
Thanks, doing some further testing it seems this may be the normal result when you "wr mem". Once any sort of config is on the FCPFQ it seems to go away.
