MultiLink PPP 2xSTM-4
yoeyblack
Hi.
We have a customer connected over 2xSTM-4, and we would like to load balance over the two links. The main idea is that we would like also to rate limit them to 800Mbit/s , but that seems to be rather difficult when you have two physical interfaces. So we thought perhaps bundling the interfaces togheter in one virtual one, using ML-PPP will solve the problem. I would like to know if anybody has already done such type of configs and how well it performs ?
Or any other idea to solve the problem is welcomed.
Thank,
Yo
you could indeed use multilink and apply a QoS on the Multilink interface limiting the bandwidth to 800K.
The config would look like this:
interface Multilink1
no ip address
service-policy output MULTILINK
ppp multilink
ppp multilink-interleave
multilink-group 1
interface Serial0/0
ppp multilink
multilink-group 1
interface Serial0/1
ppp multilink
multilink-group 1
class-map match-any STM
match access-group 101
policy-map MULTILINK
class STM
police cir 800000 bc 16000 be 32000
conform-action transmit
exceed-action drop
Instead of dropping all excess traffic, you could also specify to set a precedence, or check the other options you have available after the 'exceed-action' option...
HTH,
GP
Hello GP,
Thanks for your message. But actually I was thinking at a much higher speed. 800 Megabits per second, as the aggregate of two STM-4 are a bit more than 1.2Gbps.
So I'm worried about the performance issues that our GSRs will have to support. Any experience at high speeds?
Otto
Hello Otto,
sorry about that, I didn't realize these were STM4's. In that case, you could use the 'rate-limit' command under the multilink interface:
rate-limit input 840000000 1680000 2520000 conform-action transmit exceed-action drop
The GSR should be able to easily handle that...that said, I have no equipment to test this setup...
HTH,
GP
