08-23-2007 03:36 AM - edited 03-03-2019 06:26 PM
hello,
i have install a router 7200 with a serial and E1 interfaces.
i configure the dialer interface as a backup of serial interface, but whene i shutdown the serial the dialer stay in standby mode.
can any one help me pleaz
08-23-2007 05:09 AM
Choose another interface that does go down when the primary dies
Use either floating static routes or dialer watch for backup.
Dharmesh Purohit
08-23-2007 06:25 AM
imane
What you are encountering is a normal aspect of configuring backup interface. When you configure a primary interface with backup interface pointing to something like ISDN the ISDN goes into a special standby state and will not activate until there is a failure of the primary. And shutdown does not qualify as a failure. You must actually make the primary go into line protocol down state (not administratively down) for the backup to activate.
This is one of the reasons why many people are using floating static routes or dialer watch for backup purposes instead of using the backup interface concept.
Rick
