priority queuing for voice
saidfrh
What is the protocol type for voice? We are configuring a router and would like to designate voice traffic as high priority with all other traffic as medium priority.
router(config)# access-list 101 permit tcp any any eq ???
Thanks.
mounir.mohamed
Level 7
Level 7
RTP communications occur on an even UDP port, VoIP traffic uses a well-known UDP port range, 16384-32767. While the actual ports used are dynamically negotiated between end-devices or gateways, For UDP and similar protocols, RTP uses an even port number and the corresponding RTCP stream uses the next higher (odd) port number.
Example:
access-list 100 permit udp any any range 16384 32767
OR
Class-map test
match protocol rtp audio
here is the RFC for RTP.
http://www.ietf.org/rfc/rfc1889.txt
So far now you should understand which traffic shall you classify, the next step is which Qos method will you use, Legacy, MQC...etc
Pls rate helpful posts.
Best Regards,
Mounir Mohamed
