QoS or Traffic-shaping for IP-phone ?
lamin.sonko
I'm trying to prioritize traffic between to phone-servers on diffrent locations. On one side there is a vpn
3000, so there i cant do so much. So I'm looking at the other side (no many say, if I want to run QoS it
should be all the way). But is there a chance to either run QoS or traffic shaping on one side.
contention 20:1 upstream 800 kbs (min 40 kbs)
VPN tunnel site-to-site.
Host A is talking to Citrix-server on site B
Phone-server A is talking to Phone-server B and should be prioritize.
I have setup a lab on this, see attachment-->QoS.jpg .
when i try to use QoS on "ATM 0", i cant see any difference in traffic. Is this because i only use qos on
one side?
To test QoS i use FTP-server to see if the router prioritize traffic. But when i try the have equal amount
of bandwith and this is not the result i wanted.
When i use traffic-shaping it is seems to working greatwith FTP (dont know about IP-phones), but this
solution seems to be a little bit static, rather use som QoS. My understanding is that there is no
possibility to use QoS -->input on a interface?
Is there anyone who can tell me if I should use QoS (how), or if it will work fine with traffic-shaping.
SiteA#sh run
class-map match-any IPtel2
match access-group 100
match access-group name IPtel
policy-map localQoS
class IPtel2
shape average 400000 400000 400000
class class-default
fair-queue
shape average 150000
policy-map MinQoSpolicy
class IPtel
priority 1150
class class-default
fair-queue
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key cisco address 194.x.x.1
crypto ipsec transform-set trans1 esp-3des esp-md5-hmac
crypto map MYMAP 10 ipsec-isakmp
set peer 194.x.x.1
set transform-set trans1
match address 150
qos pre-classify
interface FastEthernet0/0
bandwidth 1544
ip address 192.168.100.1 255.255.255.0
duplex auto
speed auto
service-policy output localQoS
interface Ethernet1/0
no ip address
half-duplex
! (This interface represent the ATM interface)
interface Serial1/0
ip address 194.x.x.2 255.255.255.0
no ip mroute-cache
clock rate 384000
crypto map MYMAP
service-policy output MinQoSpolicy
ip http server
no ip http secure-server
ip classless
ip route 192.168.1.0 255.255.255.0 194.9.4.1
ip access-list extended IPtel
permit ip host 192.168.100.10 any
access-list 100 permit ip host 192.168.1.10 host 192.168.100.10
access-list 150 permit ip 192.168.100.0 0.0.0.255 192.168.1.0 0.0.0.255
//lamin
Apologize for my bad English
6 Replies 6
lamin.sonko
siteA#sh policy-map int
FastEthernet0/0
Service-policy output: localQoS
Class-map: IPtel2 (match-any)
166330 packets, 173901128 bytes
5 minute offered rate 316000 bps, drop rate 0 bps
Match: access-group 100
5 minute rate 316000 bps
Traffic Shaping
Target/Average Byte Sustain Excess Interval Increment
Rate Limit bits/int bits/int (ms) (bytes)
400000/400000 100000 400000 400000 1000 50000
Adapt Queue Packets Bytes Packets Bytes Shaping
Active Depth Delayed Delayed Active
- 0 136016 142623452 1908 1817680 no
Class-map: class-default (match-any)
48917 packets, 67095947 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
Traffic Shaping
150000/150000 1950 7800 7800 52 975
- 0 25023 33760923 19087 26177334 no
Serial1/0
Service-policy output: MinQoSpolicy
Class-map: IPtel (match-any)
87049 packets, 3938988 bytes
Match: access-group name IPtel
87051 packets, 3939032 bytes
5 minute rate 0 bps
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 1150 (kbps) Burst 28750 (Bytes)
(pkts matched/bytes matched) 103/11148
(total drops/bytes drops) 0/0
24552 packets, 1098349 bytes
Match: any
Queueing
siteA#
Friend,
There is no need to have a service-policy on the Fastethernet interface.
Voice will have detrimental effect if you shape it.
If you want to shape the traffic, then you should create a nested policy where you prioritise the voice packet.
eg
policy-map localQoS
class class-default
shape average
service-policy voice-----------Nested policy
policy-map voice
class IPtel
priority 1150
Apply it to the ATM interface
interface Serial1/0
Hi mtechnology
Ok I think i understand what you mean. I just want to prioritize trafic between the two IP-phone servers, but can only do this prioritizing on one side, with Qos or traffic-shaping not both at the same time. I was thinking to use QoS on ATM interface(in my lab didnt work, maybe some wrong with my config or there need to Qos on the other side- VPN3000, doesnt support QoS) or use traffic-shaping to allways have some bandwidth for the IP-servers. Is traffic-shaping the best alternativ?
//Lamin
You should only do marking on your LAN input.
Then QOS output on wan interface.
Qos output on you LAN is not necesarry.
Traffic-shaping is a technique for limiting traffic, so if you limit unimportant traffic you get more bandwith for Voice.
However it is better to do LLQ for voice and reserve a minimum bandwith.
And of cource to get full utilization of QOS you need it on both ends for. (Return traffic)
Bjornarsb
Hi Bj?rn
on the other side there is a VPN3000 it cant prioritize traffic. So I can only do this on one side. When I did my lab with traffic-shaping I could dedicate bandwidth for the IP-phone servers. This by only do some config on one side on Fa0/0 inteface-->output, this seems to work fine. But I rather use QoS is this possible?
//Lamin
Yes you can use QOS.
Please have a look at this example:
Create a child or lower-level policy that configures a queueing mechanism. In the example below, we configure LLQ using the priority command and CBWFQ using the bandwidth command. Refer to Congestion Management Overview for more information.
policy-map child
class voice
priority 512
Create a parent or top-level policy that applies class-based shaping. Apply the child policy as a command under the parent policy since the admission control for the child class is done based on the shaping rate for the parent class.
policy-map parent
class class-default
shape average 2000000
service-policy child
Apply the parent policy to the subinterface.
interface ethernet0/0.1
service-policy parent
HTH,
Bjornarsb
