Re: G.703 Card ...
InternetB
[1] I need some advice on the use of the command ' channel-group 0 timeslots 1-31'. I am using a G.703 card.
To my understanding the above command means that there are effectively 32 channels of 64K and can be used for voice or data.
My question is that if I just want to use the total bandwidth of the E1, I should do 'channel-group <channel-group-no> unframed right ? This would effectively give me the total
bandwidth of the link.
[2] With respect of the 'channel-group' command, if I had this for example :-
channel-group 8 timeslots 5,7,12-15,20 speed 64
channel-group 12 timeslots 2
What does the numbers of 0, 8 and 12 mean here ? Is it any random number that we can use here ?
Thank you,
Cheers,
- InternetB -
satish_zanjurne
Level 4
Level 4
hi,
1. it is not any random number.
2.Based on the channel-group your logical serial interface will be created
e.g if channel-group is 9 serial interface will contain 8
3.For E1 channel-group number range is 0-30
HTH..rate if helpful..
You did not answer my question. My question was :-
My question is that if I just want to use the total bandwidth of the E1, I should do 'channel-group unframed right ? This would effectively give me the total bandwidth of the link.
[2] With respect to the 'channel-group' command, if I had this for example :-
What does the numbers of 0, 8 and 12 mean here ? Is it any random number that we can use here ? Or rather is there a limit on this number and the timeslots would be 24 channels and 32 channels for T1 and E1 respectively ?
* modified the 2nd question a bit from the earlier posting.
- InternetB -
