02-26-2008 12:15 AM - edited 03-03-2019 08:52 PM
1. This is a routing table, what is this network topology ?
C 192.168.1.96/27 is directly connected, Serial1
C 192.168.1.98/32 is directly connected, Serial1
C 192.168.1.64/27 is directly connected, Serial0
C 192.168.1.66/32 is directly connected, Serial0
R 192.168.1.33/32 [120/1] via 192.168.1.98, 00:00:05, Serial1
R 192.168.1.32/27 [120/1] via 192.168.1.66, 00:00:07,Serial0
R 192.168.1.34/32 [120/1] via 192.168.1.66, 00:00:07, Serial0
2. what does 192.168.1.96/27 mean?
3. what does 192.168.1.98/32 mean?
02-26-2008 12:37 AM
192.168.1.98/32 is the loopback ip.
192.168.1.96/27 is the network address which is directly attached.
R means routes coming from RIP network.
regards
shivlu
02-26-2008 01:02 AM
When you use PPP, the Cisco IOS will automatically create a /32 route for the neighbor by default
Hence you see 2 network statements, one is the /32 address and the other is the attached network
If you want to disable this feature configure the following command under the interface
no peer neighbor-route
http://www.cisco.com/en/US/docs/ios/11_3/dial/configuration/guide/dcppp.html#wp6109
Narayan
