testing secirity of a router
saidfrh
I have installed a Cisco 2821 perimeter router and ASA firewall for a business. How can I test the security of the router? The router has firewall features. Would it be redundant to configure the firewall features in the router, since there is a ASA firewall protecting the LAN and DMZ?
2 Accepted Solutions
Jon Marshall
Said
Have a look at the following link for information on hardening a Cisco router
http://www.sans.org/reading_room/whitepapers/firewalls/794.php
Also have a look at this recent thread for an idea of the sort of filtering you should do on an Internet facing router
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=General&topicID=.ee6e1f8&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc23923
In answer to your question, yes i think it would be redundant to use the firewalling capabilities of the router if you have a firewall like the ASA protecting the LAN and your DMZ.
Jon
Additionally to Jon's post and links-
I try and keep the following link current. It's an ACL for internet routers. This ACL is for DoD/NIST compliance.
http://www.packetpros.com/wiki/index.php/What%27s_the_current_DITSCAP/DIACAP_ACL_for_a_public_interface%3F
(hyperlink doesn't always work, so try copy-n-paste)
Hope that helps.
7 Replies 7
Jon Marshall
Jon
Hope that helps.
Collin, Thanks. Said
Jon,
Thanks. You are awesome.
Jon,
States of vulnerabilities in the IOS. How do you patch the IOS, is it like Windows patching system?
Said
no the IOS is not patched like windows
cisco releases updates of the ios
so its a new .bin file
you would have to get the new IOS release and depending on your router erase the old ios and copy the new to the router
IOS's have multiple releases within a version
Also note, unlike Windows, most updates to IOS are not free. However, for some security issues, Cisco does provide free updates.
