Unable to access Internet behind Cisco 2811 Router
westernmotor
We had a power outage last night, and since then, we've been unable to access the Internet from within the internal network (behind the 2811 series ). I can remote in from outside, so that means my NAT statements are working for port 3389. I can also access internal webmail site from public side. However, no Internet on the inside. I've attached the running-config if someone could point me in the right direction. I'm very stuck.
gatlin007
Level 4
Level 4
It looks like you may need to change the route-map in the following nat statement:
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/1 overload
SDM_RMAP_1 will only nat if destined to 192.168.1.0/24
Change it to this:
ip nat inside source route-map SDM_RMAP_2 interface FastEthernet0/1 overload
This route map matches an ACL that permits all destinations.
Chris
Atif Awan
Your NAT overload statement refers to route-map SDM_RMAP_1 which is using an ACL that will result in NAT of traffic from 10.4.167.0 to 192.168.1.0. A quick suggestion will be to take a look at this overload statement and possibly tra SDM_RMAP_2 instead of SDM_RMAP_1.
Atif
kyukim
I reviewed your config and found a problem.
route-map SDM_RMAP_1 permit 1
match ip address 104
access-list 104 remark SDM_ACL Category=2
access-list 104 remark IPSec Rule
access-list 104 permit ip 10.4.167.0 0.0.0.255 192.168.1.0 0.0.0.255
So, currently, only traffic matching ACL 104 is NAT translated and Internet traffic is not being translated.
You need to chang route-map SDM_RMAP_1 to match different ACL.
no match ip address 104
no match ip address 109
access-list 109 deny ip 10.4.167.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 109 permit ip 10.4.167.0 0.0.0.255 any
KK.
I understand the correct Route-Map would be
match ip address 105
