07-01-2009 09:14 PM - edited 03-04-2019 05:17 AM
NM-16ESW modules into 3700 creates an vlan 1 interface.IS this the mangement interface for switching module
or what is the purpose of assigning ip address to this vlan 1.
07-01-2009 09:35 PM
IP Address for VLANs are purely for management purposes only. You can, if you like, leave VLANs with no IP Address but what do you do when you need to configure the switch?
Hope this helps.
07-01-2009 09:53 PM
Muhammad
Leo's response is oriented more to a standalone layer 2 switch. Whether it is appropriate in your case depends on whether you leave the ports in the switch module in the default of VLAN 1 or whether you assign the switch ports to other VLANs. As long as the ports in the switch module are in VLAN 1 then they need a layer 3 interface to provide routing for the subnet to which they all belong. And the interface vlan 1 with its IP address is providing the routing for that subnet. So its function is more than just management of the switch.
Rick
07-01-2009 11:04 PM
Thanks for reply,
Following is the configuration of Switching module in router.
interface FastEthernet1/0
switchport access vlan 5
switchport mode trunk
interface FastEthernet1/1
no switchport
ip address 10.1.1.1 255.255.255.0
interface FastEthernet1/2
no switchport
ip address 10.2.2.1 255.255.255.0
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface Vlan1
ip address 202.X.X.X 255.255.255.0
interface Vlan5
no ip address
router ospf 1
network 202.x.x.x 0.0.0.255 area 0
Can someone elaborate the above configuration including the purpose of ip address of vlan 1.
