07-08-2008 04:16 AM - edited 03-03-2019 10:38 PM
I have two 6500 switch and both are in Server Mode. I have configured Same Domain name on both. Now I create Vlan 2, 3 & 4 on One Switch. Is it replicated to Second Switch ?
07-08-2008 04:32 AM
It is replicated to Second Switch.
07-08-2008 04:47 AM
Yes, It should replicate if you have configured identical password and domain.
- Dharmesh Purohit
07-08-2008 05:04 AM
Yes, provided:
1. There is a trunk between the switches,
2. The domain name matches,
3. The domain password (if any) matches,
4. The second switch has an equal or lower config revision than the first switch.
Kevin Dorrell
Luxembourg
07-08-2008 05:22 AM
Hi Kevin,
I am looking for some suggetion from your side for CCIE LAB (Routing & Switching). What is your Email ID?
07-08-2008 06:36 AM
Sure, it sounds like Kevin dot Dorrell at pt dot lu.
But just to add ... anything we discuss should be strictly subject to the Cisco NDA (Non-Disclosure Agreement). I am quite paranoid about that.
Kevin Dorrell
Luxembourg
07-08-2008 06:38 AM
Hi Kevin,
You are right, I have tested it.
Beside this, I want to discuss some more problem of CCIE Lab with you. My Email ID is rupnkashyap@yahoo.co.in. I am looking for your test mail on this ID, if possible , so that I can share my problems.
