Обрывы связи на частоте 5ГГц
Клиент подключен к точке доступа на частоте 5ГГц (ноутбук Sony Vaio) (SSID: WiFi-UE-Group). Точки доступа находятся в едином WDS. Конфигурация стандартная (cisco AP1142N-R-K9). При передачи данных начинаются обрывы связи и переподключение. Сигнал в районе -60 -65dbi, при этом на интерфейсе видно следующее:
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 101 mode ciphers tkip
encryption vlan 102 mode ciphers aes-ccm tkip
encryption vlan 103 mode ciphers aes-ccm tkip
encryption vlan 104 mode ciphers aes-ccm tkip
encryption vlan 105 mode ciphers aes-ccm tkip
encryption vlan 106 mode ciphers aes-ccm tkip
encryption vlan 1101 mode ciphers aes-ccm tkip
ssid UE-WiFi
ssid UEG-CCKM-ROAMING
ssid UEG-WPA-ENTERPRISE
ssid UEG-WPA-PSK
ssid UEG-WPA-ROAMING
ssid WiFi-UE-Group
ssid WiFi-UE-Printers
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1.101
encapsulation dot1Q 101
no ip route-cache
bridge-group 101
bridge-group 101 subscriber-loop-control
bridge-group 101 block-unknown-source
no bridge-group 101 source-learning
no bridge-group 101 unicast-flooding
bridge-group 101 spanning-disabled
interface Dot11Radio1.102
encapsulation dot1Q 102
no ip route-cache
bridge-group 101
interface Dot11Radio1.103
encapsulation dot1Q 103
no ip route-cache
bridge-group 101
interface Dot11Radio1.104
encapsulation dot1Q 104
no ip route-cache
bridge-group 101
interface Dot11Radio1.105
encapsulation dot1Q 105
no ip route-cache
bridge-group 101
interface Dot11Radio1.106
encapsulation dot1Q 106
no ip route-cache
bridge-group 101
interface Dot11Radio1.1101
encapsulation dot1Q 1101
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 port-protected
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
AP1-3#sh interfaces dot11Radio 1
Dot11Radio1 is up, line protocol is up
  Hardware is 802.11N 5GHz Radio, address is 0c85.2566.f960 (bia 0c85.2566.f960)
  MTU 1500 bytes, BW 54000 Kbit/sec, DLY 1000 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Last input 00:30:47, output 00:00:00, output hang never
  Input queue: 0/1677/10/0 (size/max/drops/flushes); Total output drops: 18060311
  Queueing strategy: fifo
  Output queue: 0/30 (size/max)
     9282321 packets input, 1971892463 bytes, 894070 no buffer
     Received 72090 broadcasts, 0 runts, 0 giants, 0 throttles
     92672453 packets output, 3178870121 bytes, 0 underruns
     103 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
AP1-3#sh controllers dot11Radio 1
Radio AIR-AP1140A, Base Address 0c85.2566.f960, BBlock version 0.00, Software version 3.00.75
Serial number: FOC15465EGN
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: Russia 5G-Band (RU) (-R)
Uniform Spreading Required: No
Configured Frequency: 5680 MHz  Channel 136
Allowed Frequencies: 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(60) 5320(64) 5660(132) 5680(136) 5700(140) 5745(149) 5765(153) 5785(157) 5805(161)
Listen Frequencies: 5170(34) 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(60) 5320(64) 5500(100) 5520(104) 5540(108) 5560(112) 5580(116) 5600(120) 5620(124) 5640(128) 5660(132) 5680(136) 5700(140) 5745(149) 5765(153) 5785(157) 5805(161) 5825(165)
Beacon Flags: 0, Interface Flags 20105, Interface Events 0, Mode 9; Beacons are enabled; Probes are enabled
Configured Power: 17 dBm
Active power levels by rate
     6.0 to 24.0  , 14  dBm, changed due to regulatory maximum
    36.0 to 36.0  , 13  dBm, changed due to regulatory maximum
    48.0 to 48.0  , 12  dBm, changed due to regulatory maximum
    54.0 to 54.0-b, 11  dBm, changed due to regulatory maximum
     m0. to m3.   , 14  dBm, changed due to regulatory maximum
     m4. to m4.   , 13  dBm, changed due to regulatory maximum
     m5. to m5.   , 12  dBm, changed due to regulatory maximum
     m6. to m6.   , 11  dBm, changed due to regulatory maximum
     m7. to m7.   , 10  dBm, changed due to regulatory maximum
     m8. to m11.  , 14  dBm, changed due to regulatory maximum
    m12. to m12.  , 13  dBm, changed due to regulatory maximum
    m13. to m13.  , 12  dBm, changed due to regulatory maximum
    m14. to m14.  , 11  dBm, changed due to regulatory maximum
    m15. to m15.  , 10  dBm, changed due to regulatory maximum
   m0.-4 to m3.-4 , 14  dBm, changed due to regulatory maximum
   m4.-4 to m4.-4 , 13  dBm, changed due to regulatory maximum
   m5.-4 to m5.-4 , 12  dBm, changed due to regulatory maximum
   m6.-4 to m6.-4 , 11  dBm, changed due to regulatory maximum
   m7.-4 to m7.-4 , 10  dBm, changed due to regulatory maximum
   m8.-4 to m11.-4, 14  dBm, changed due to regulatory maximum
  m12.-4 to m12.-4, 13  dBm, changed due to regulatory maximum
  m13.-4 to m13.-4, 12  dBm, changed due to regulatory maximum
  m14.-4 to m14.-4, 11  dBm, changed due to regulatory maximum
  m15.-4 to m15.-4, 10  dBm, changed due to regulatory maximum
   6.0-d to 24.0-d, 14  dBm, changed due to regulatory maximum
  36.0-d to 36.0-d, 13  dBm, changed due to regulatory maximum
  48.0-d to 48.0-d, 12  dBm, changed due to regulatory maximum
  54.0-d to 54.0-d, 11  dBm, changed due to regulatory maximum
  OffChnl Power: 14, Rate 6.0
Allowed Power Levels:  -1 2 5 8 11 14 17
Allowed Client Power Levels: 2 5 8 11 14 17
Receive Antennas : right-a left-b middle-c
Transmit Antennas : right-a left-b, ofdm all
Antenna: internal, Gain: Allowed 8, Reported 0, Configured 0, In Use 8
Active Rates:  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
Current Rates:  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
Allowed Rates:  6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates:  6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
Default Rates:  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
Best Range Rates:  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
Best Throughput Rates:  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
Current Voice Rates:  basic-6.0 basic-12.0 basic-24.0 [disabled until voice packet-discard enabled]
Default Voice Rates:  basic-6.0 basic-12.0 basic-24.0
Managment Rates:  basic-6.0
Multicast Rates:  basic-6.0 basic-12.0 basic-24.0
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 6.0, 15, -89)   ( 9.0, 16, -88)   (12.0, 18, -88)   (18.0, 19, -86)
(24.0, 20, -85)   (36.0, 24, -81)   (48.0, 27, -78)   (54.0, 31, -77)
Legacy Beamforming: Configured No, Active No
TX A-MPDU Priority: 0x31
Guard-Interval: Any
HT protection: HT (no protection).
Neighbors with non-HT members:
Number of MFP Indices: 10
RFID Tag Detection: Disabled
Multicast Address filtered:
Packet type filtered:
00 0C rm_scn
Probe limit: active off, filter on, count 0, time 0
Assoc limit: active off, count 0, time 0
Radio Management (RM) Configuration: Regular AP, Mode 1, Disabled
MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0 [5]0x0 [6]0x0 [7]0x0 [8]0x0
TKIP Cum Stats: STA            MIC-L-Errs MIC-R-Errs Replay   C-Measure
                0000.0000.0000 00000000   00000000   00000000 00000000
AES-CCMP Cum Stats: 00000000 replays discarded
QBSS Load: 0x0, Policing Stats: Rx downgrades 0, Tx downgrades 0
Classifier Stats tx_on_up6  0, tx_on_up4 0
Configured Local Access Class Parameters
  Back      : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0
  Best      : cw-min 4 cw-max 6 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 3 cw-max 4 fixed-slot 1 admission-control Off txop 3008
  Voice     : cw-min 2 cw-max 3 fixed-slot 1 admission-control Off txop 1504
Configured Cell Access Class Parameters
  Best      : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 3008
  Voice     : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 1504
SIP stats sip_udp_rx_pkt 0, sip_tcp_rx_pkt 0,
                            downlink classified_pkt 0,
                            uplink classified_pkt 0,
                            num_processed_SIP_Calls 0
Transmit queues: Limit 646 Current 0 In-Progress 0
       ---- Active --- In-Progress --------------- Counts --------------
       Cnt Quo Bas Max Cnt Quo Bas       Sent   Discard  Fail    Retry  Multi
Uplink   0   0   0   0   0   0   0          0         0     0        0      0
Voice    0   2 430   0   0   2 100     660731     24020    99      340    130
Video    0   0   0   0   0   0   0       3316        77     0       32     18
Best     0   3 215   3   0   3  50   88424948   1766871    44   692012 322866
Mcast    0   0   0   0   0   0   0    3291519   6913671     1    38623  12141
Back     0   0   0   0   0   0   0    3291519   6913671     1    38623  12141
BSSIDS Index Flags State Next Held Defer NonDefer Clients Tsf Dtim Txq
  F960     0    20     0    0    0     0        0       0   0    2   0e
Driver TX blocks: in use 0, high 0, at reset 0, fail 8 drop 8
Off Channel Metrics: Timeouts - Tx 0 Beacon 0 DTIM MC Waits 0
---Clients     AID VLAN      Status    Age  Tx   Mode Enc Key       Rate
                 RxPkts KBytes  Dup Dec Mic   TxPkts  KBytes  Retry RSSI SNR
               IP Address      Pauses   RSC
Video Report:  Cnt  Rate  Retries/Tot
В чем может быть причина?
1 REPLY
Что входит шоу? вы пробовали заглянуть в журналы?
Попробуйте, пожалуйста, чтобы использовать английский язык. Большинство людей здесь не понимают русского языка.
Спасибо,
Amjad
Rating useful replies is more useful than saying "Thank you"
221
