1042 not joining to wlc 2504
i have a WLC 2504, when i reboot it all the ap will be joined the wlc . But when i reboot one AP, it can't rejoin the wlc and i have the following error :
LWAPP_CLIENT_EVENT: Dropping discovery in LWAPP. This AP model is not supported by LWAPP WLC.
*Mar  1 00:03:24.956: LWAPP_CLIENT_EVENT: Dropping discovery in LWAPP. This AP model is not supported by LWAPP WLC.
*Mar  1 00:04:02.958: LWAPP_CLIENT_EVENT: Dropping discovery in LWAPP. This AP model is not supported by LWAPP WLC.
I need to restart the wlc in order the ap to rejoin it .
Have you got an idea ?
the wlc version is : 7.4.121.0
the ap version : 15.2(2)JB3
Best regards
VIP Purple
Can u paste the output of
Can u paste the output of these commands:
from WLC: sh sysinfo
From AP: sh version
Manufacturer's Name..........
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.121.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_66:55:e4
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 172.18.1.106
Last Reset....................................... Software reset
System Up Time................................... 0 days 6 hrs 30 mins 12 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... FR  - France
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
External Temperature............................. +47 C
Fan Status....................................... 5000 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 3
Number of Active Clients......................... 1
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 54:78:1A:AC:79:80
Maximum number of APs supported.................. 10
AP6073.5c2f.5625#sh version
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 15.2(2)JB3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 19-Dec-13 04:41 by prod_rel_team
ROM: Bootstrap program is C1040 boot loader
BOOTLDR: C1040 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
AP6073.5c2f.5625 uptime is 6 hours, 27 minutes
System returned to ROM by reload
System image file is "flash:/c1140-k9w8-mx.152-2.JB3/c1140-k9w8-mx.152-2.JB3"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1042N-E-K9    (PowerPC405ex) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FCZ1636Z2VT
PowerPC405ex CPU at 333Mhz, revision number 0x147E
Last reset from reload
LWAPP image version 7.4.121.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 60:73:5C:2F:56:25
Part Number                          : 73-14034-05
PCA Assembly Number                  : 800-34273-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16310UZH
Top Assembly Part Number             : 800-34285-04
Top Assembly Serial Number           : FCZ1636Z2VT
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1042N-E-K9
Configuration register is 0xF
VIP Purple
Hi,Can you connect AP with
Can you connect AP with console cable, reboot the AP and paste the entire bootup process here.
Hi,I can't ... the access
I can't ... the access point is hooked to 10m high ...
Yes, I think it should be
Yes, I think it should be country code mismatch.
Hall of Fame Super Gold
Something is NOT RIGHT here.
1.  Why is the error message saying "LWAPP"?  If you are running 7.X then you shouldn't be seeing "LWAPP" anywhere.
2.  Look at the logs.  Your time and date are incorrect.  Fix this up.
Are you sure, the output to the command "sh sysinfo" is correct?   Maybe you're giving us an output from another WLC?
No no it's the good WLC ...
Then fix the time-and-date of
Then fix the time-and-date of your WLC.
No change after the fix of
No change after the fix of the time and date ...
I need to reboot the WLC every days ...
If you need to reboot the WLC
If you need to reboot the WLC daily (why?) then I'd recommend you enable NTP.
Hola a todosA mi me pasa algo
Hola a todos
A mi me pasa algo muy parecido, tengo un wlc 2504 y unidos a la controladora APs AIR-LAP 1252 y AIR-CAP3501, despues de interconectar fisicamente todo, procedo a la configuracion del wlc y todo me corre bien. Pero si por algun motivo quito la energia los APs me salen "NO JOINED", hasta ahora lo unico q me funciono es volver a configurar el wlc, entonces si los reconoce y todo normal
Por favor soy nueva en esto, y necesito ayuda.
Agradecida de antemano espero sus respuestas
esto es lo q me responde a los comandos
From AP: sh version
(Cisco Controller) >show sysinfo
Product Version.................................. 7.0.116.0
Firmware Version................................. PIC 15.0
System Name...................................... wlc-bjo
IP Address....................................... 10.200.0.240
Last Reset....................................... Power on reset
System Up Time................................... 0 days 1 hrs 6 mins 46 secs
Current Boot License Level....................... base
Current Boot License Type........................ Permanent
Next Boot License Level.......................... base
Next Boot License Type........................... Permanent
Configured Country............................... US  - United States
Internal Temperature............................. +23 C
External Temperature............................. +26 C
Fan Status....................................... 3696 rpm
State of 802.11a Network......................... Disabled
Number of Active Clients......................... 0
Burned-in MAC Address............................ D0:C2:82:DF:42:A0
Maximum number of APs supported.................. 15
TecnologiaP2-2>show version
Cisco IOS Software, C1250 Software (C1250-K9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 13:05 by prod_rel_team
ROM: Bootstrap program is C1250 boot loader
BOOTLDR: C1250 Boot Loader (C1250-BOOT-M) Version 12.4(18a)JA1, RELEASE SOFTWARE (fc1)
TecnologiaP2-2 uptime is 6 hours, 55 minutes
System image file is "flash:/c1250-k9w8-mx.124-23c.JA2/c1250-k9w8-mx.124-23c.JA2"
export@cisco.com.
cisco AIR-LAP1252G-A-K9    (PowerPC 8349) processor (revision B0) with 49142K/16384K bytes of memory.
Processor board ID FTX1316904G
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
LWAPP image version 7.0.116.0
1 802.11 Radio(s)
Base ethernet MAC Address: 00:24:C4:51:DD:66
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC13103G43
Top Assembly Part Number             : 800-29532-03
Top Assembly Serial Number           : FTX1316904G
Product/Model Number                 : AIR-LAP1252G-A-K9
Looks like country code
Looks like country code mismatch between WLC and AP. Please make them same and try again.
392
