Community Member
1130 AG AP and Broadcast of the SSID
We have 3 1130's installed and 2 vlans, one public and one private. I need to broadcast my private SSID but cannot find the setting to allow this. Can someone advise me on the location of the setting?
chaz
Re: 1130 AG AP and Broadcast of the SSID
Charles,
     I assume you are using IOS (Autonomous) Access points.. if so you need to enable guest-mode on the Dot11 SSID
so it would look something like this
dot11 ssid private
    vlan x
    guest-mode
Hope this helps.. Please feel free to rate it.
Community Member
Forgive my response/confusion but in using the web interface, where is this setting held?
Bronze
It should be under Security -> SSID towards the bottom of the page you will need to scroll the select Guest ID and the SSID you want broadcast.
Bill
Community Member
Dumb follow up, but the device cant broadcast both SSID's?
Hall of Fame Super Blue
Yes, you can broadcast up to 16 SSID.
Community Member
I can get one or the other to broadcast but not both. What am I doing incorrect?
Go to Security > SSID Manager.  Highlight the SSID you want and go down and tick "Set SSID as Guest Mode".
Don't forget to rate our posts.  Thanks.
3584
