1140 PEAP IAS Issue
Hi everyone,
I am trying to set up a 1140 IOS (stand alone) access point with MS IAS server using PEAP.
Everything is working, users can connect and authenticate with the access point, I see successes in the IAS log.
But once connected no data can be passed so no IP address is recieved by the client and if I sent it to a manual IP nothing can be pinged.
There are no errors in the AP or IAS logs.
I have tried the access point on 2 totally different domains with the same results.
I have had this working fine in the past with 1130 AP's
Any ideas much appreciated?
thanks
Everyone's tags (3)
Re: 1140 PEAP IAS Issue
Just to add the AP works fine in WPA2-PSK mode.
Hall of Fame Super Silver
Take a look at this troubleshooting guide and run the debug commands.  Doesn't really look like authentication is working completley.  When you switch to WPA2-PSK everything works, so your network portion is good.  So that leaves the EAP configuration to troubleshoot.
http://www.ciscosystems.am/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml#tshoot
-Scott
Thanks Soctt.
I will have a look but I am getting this on that URL:
Invalid URL
The requested URL "/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml", is invalid.
Reference #9.b1caf6cf.1269606204.92f8e80
Here is the pdf version.
-Scott
Thanks Scott, I will take a look.
Run the debug commands and post the log if you see anything.
-Scott
933
