Community Member
1142 not renewing lease
Strange thing happening and I cant seem to find if its a bug or not. There are some AP's overseas configured for Flexconnect and occasionally they drop off the controller. When I check the AP using CDP neigh on the switch it doesnt have an IP. After a power cycle, power inline never, the AP gets an IP and joins up and works fine.  This appears to be timed based on the IP lease. Its the only thing I can think that could cause it at this point.
1 REPLY
VIP Purple
What is the WLC software version you are running ? if possible post "show sysinfo" output of your WLC
Rasika
158
