Community Member
1242's and Mac OSX ?
I have several 1242's in my environment using Radius for EAP authentication. I have a small number of Mac users who cannot get connected via this method...
Can someone offer me an alternative configuration....I basically have a red and a green SSID. Red is outbound only, green is inside and can see all network resources.
Thanks.
Hall of Fame Super Silver
Re: 1242's and Mac OSX ?
Take a look at this link from OSU:
http://8help.osu.edu/2666.html
-Scott
Community Member
Thanks....It doesnt really help much though. My Windows users are not the issue, its my Mac folks in Marketing... The Cisco 1242AG is not allowing the airports to establish a connection. I know my AP's are working I am just not sure about the best (correct) way to allow a Mac to connect.
Thanks for your link.
I have mac clients running on may of my clients wlan. Check th edriver version on the mac's and maybe it needs some updating. This link is how to configure PEAP on MAC OSX:
http://jason-shave.blogspot.com/2008/04/configure-mac-osx-wi-fi-for-peap.html
You are using PEAP correct?
-Scott
137
