02-11-2014 05:09 PM - edited 07-05-2021 12:09 AM
I have a 1300 AP that is in Bridge mode. I can always ping the access point, no network connectivity issue to AP. The issue that I'm having is the Printer connected to the AP. When I ping the printer from my laptop it will time out. If I log into the AP send a ping to the printer it will work. Once the ping sent from the AP it will start pinging from laptop as well. I have tried another printer it does the same thing. I have also manualy set the duplex to full. That did not help either. So basically I can't ping the printer unitl I start up a ping from the AP that it is connected to first. Just wondering if anyone else has ever ran into this.
02-11-2014 05:59 PM
You might be loosing the arp entry... the printer might not be responding back so the arp will timeout. You can try to create a static arp entry on your layer 3.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
02-11-2014 06:35 PM
Added the static arp. We will see what happens.
02-11-2014 06:37 PM
Did you see the arp timeout by chance? Keep us posted also.
Scott
02-11-2014 07:00 PM
No dice still same issue.
02-11-2014 07:17 PM
Don't know what else you can do.
Scott
02-11-2014 07:19 PM
10/4
