2 SSIDs, WEP or WPA w/o VLANs?
It must be because it is toooo late at night for me.
I am trying to configure a 1200 with two SSIDs. One will authenticate with WEP, the other with WPA/PSK.
I can set up the WEP SSID OK but when I try to create the second SSID I seem to be told that I have to turn off the WEP key in order to enable the WPA key. I.E. it seems to be AP or radio specific and not SSID specific.
Is it just me?
Thanks, in advance,
Mike
  • Security and Network Management
1 REPLY
Re: 2 SSIDs, WEP or WPA w/o VLANs?
Mike,
Hope I can save you some time on this. Unless otherwise stated I have tried this myself and actually took it to Cisco TAC. They stated that you have to VLAN out the other authentication protocol you are using. If you are using two SSID's it will require two VLAN's unless that other SSID is a Guest SSID.
122
