2504 e multicast ip 239.0..0.0.
I have a little problem. My 2504 works fine but I have the problem that the tablet that need access to software teacher smarty cupboard pro they do not. tested with another easy access point work flawlessly. The network has a Forefront log in and see who is denied the comunicasione between 2504 and ip ip multicast present in the controller. How can you solve the problem and make sure that all the devices that connect to cisco AP does not have any kind of limitations in communicating with each other? Thank's
Everyone's tags (1)
further information tablets
further information tablets using Android. have no problem in gaining access to the network and use services such as the Internet. the problem is that you can not get them to connect to that server function nb for teaching media. if you use a ap intellinet everything works. I wonder if I need any special configuration or there is no use Compatibility of android tablet.
VIP Purple
On your 2504, did you enable
On your 2504, did you enable mDNS globally ? Go through this guide & see whether you have configured your WLC correctly for this mDNS service
http://www.cisco.com/c/en/us/td/docs/wireless/technology/bonjour/7-5/Bonjour_Gateway_Phase-2_WLC_software_release_7-5.html
Rasika
***Pls rate all useful responses ***
hy, Thank you for your
hy, Thank you for your attention. I say now because I live in Italy. I checked the guide and configuration. The mDNS is active in controller. The only thing that seems strange is that the menu item domain names is completely empty. Strange that the android tablet connected to an access point by a few euro intellinet work both for navigation and as a client of smartmediapro software. Strange that they are surfing the internet but do not start the client of educational software. I is also no doubt that the android tablet when connecting on ap cisco ip address do not get properly. Use as a srv dhcp server in this domain w2k8 active directory. Thanks again in advance for further advice. If you need more information please ask.
Tomorrow morning I can and I
Tomorrow morning I can and I want to check if the Android tablet get ip correctly because the ap are at a training center.
I solved the problem. The
I solved the problem. The software vendor has sent me new versions for both Windows that included with the Android tool ip broadcast. In 2504 the page there is a section of the controller configuration flag to enable it and it was already enabled. Updated software now works correctly.
I have to solve the second problem now. I notice that every now and then detaches and reattaches to connect to my SSID configured. In the log I see this summary and enclose only the last 10 since the remaining are equal. Why does this happen?
0 Thu Oct 9 08:36:32 2014 AP's Interface: 0 (802.11b) Operation State Up: Base Radio MAC: b0: 00: b4: 7f: 05: 80 Cause = Radio interface reset. Status: NA
1 Thu Oct 9 08:36:32 2014 AP's Interface: 0 (802.11b) Operation Down State: Base Radio MAC: b0: 00: b4: 7f: 05: 80 Cause = Radio interface reset. Status: NA
2 Thu Oct 9 08:36:32 2014 AP's Interface: 1 (802.11a) Operation State Up: Base Radio MAC: b0: 00: b4: 7f: 05: 80 Cause = Radio interface reset. Status: NA
3 Thu Oct 9 08:36:32 2014 AP's Interface: 1 (802.11a) Operation Down State: Base Radio MAC: b0: 00: b4: 7f: 05: 80 Cause = Radio interface reset. Status: NA
4 Thu Oct 9 08:36:29 2014 AP's Interface: 1 (802.11a) Operation State Up: Base Radio MAC: b0: 00: b4: 7f: 05: 80 Reset Cause = Unknown Status: NA
5 Thu Oct 9 08:36:28 2014 AP disassociated. Base Radio MAC: 2c: 3e: cf: 1c: 0e: e0
6 Thu Oct 9 08:36:28 2014 AP's Interface: 1 (802.11a) Operation Down State: Base Radio MAC: 2c: 3e: cf: 1c: 0e: Causes e0 = New Discovery Status: NA
7 Thu Oct 9 08:36:28 2014 AP's Interface: 0 (802.11b) Operation Down State: Base Radio MAC: 2c: 3e: cf: 1c: 0e: Causes e0 = New Discovery Status: NA
8 Thu Oct 9 08:36:26 2014 AP's Interface: 0 (802.11b) Operation State Up: Base Radio MAC: b0: 00: b4: 7f: 05: 80 Reset Cause = Unknown Status: NA
9 Thu Oct 9 08:36:26 2014 AP 'AULAMAGNA', MAC: b0: 00: b4: 7f: 05: 80 previously disassociated two to Link Failure. Uptime: 2 days, 18 h 54 m 40 s. Reason: CAPWAP WTP Event request.
10 Thu Oct 9 08:36:22 2014 AP disassociated. Base Radio MAC: 58: 0a: 20: de: ff: 30
75
