2504 WLC SSID Password
Where do I go to put a password on a particular SSID with WPA authentication.
1 ACCEPTED SOLUTION
As Steve mentioned, LAYER 2 .
As Steve mentioned, LAYER 2 .. See attached
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
it goes in the SSID config:
it goes in the WLAN config, under Layer 2 Security.
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
I have the same problem but I
I have the same problem but I don't have WCS anymore... what are the commands to change the old password?
6793
