2602 vs 1042 APs
We have 1042 APs through our head office. We have several 2602 APs spare. Would we gain anything by swapping them over, is there much of a difference for performance?
Everyone's tags (1)
1 ACCEPTED SOLUTION
VIP Purple
Yes, performance wise 1042 is
Yes, performance wise 1042 is 2x2:2 (ie two tx & two rx antenna with 2 spatial stream support) & max you can get 300Mbps PHY rate.
On the other hand 2602 is 3x4:3 (ie 3 tx & 4 rx antenna with 3 spatial stream support) & max you can get 450Mbps PHY rate.
You can refer this for more details.
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#~indoor
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-1140-series/data_sheet_c78-609338.html
When replacing make sure your WLC has compatible software version for these AP (if you are running 7.4.121.0 or 7.6.130.0 that should be fine)
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rasika
**** Pls rate all useful responses ****
1 REPLY
VIP Purple
Rasika
46
