2602I stand alone to LWAP conversion
kstharunraj
Is it possible to convert  AIR-SAP2602I to LWAP? I want to connect it to the WLC 5508 via flex ctonnect mode. What all are the LWAP models supported by the WLC 5508. I couldn't find these details in 5508 data sheet
Sandeep Choudhary
Yes it is possible to convert to LAP.
Here is the procedure to convert:
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
You can check here about flexconnect feature matrix:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-product-00.html
Which AP supported by WLC depends on software version.
check thsi compatibilty matrix for support AP :
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Hope it helps.
Dont forget to rate helpful posts
Sandeep Choudhary
Hope it helps.
kaaftab
Level 4
Level 4
just to more links for converting AP from stand alone to LWAP
http://targetcisco.blogspot.com/2011/01/converting-autonomous-access-point-to.html
kstharunraj
Thanks a lot Sandeep
