2602I stand alone to LWAP conversion
Is it possible to convert  AIR-SAP2602I to LWAP? I want to connect it to the WLC 5508 via flex ctonnect mode. What all are the LWAP models supported by the WLC 5508. I couldn't find these details in 5508 data sheet
1 ACCEPTED SOLUTION
VIP Purple
Yes it is possible to convert
Yes it is possible to convert to LAP.
Here is the procedure to convert:
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
You can check here about flexconnect feature matrix:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/112042-technote-product-00.html
Which AP supported by WLC depends on software version.
check thsi compatibilty matrix for support AP :
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Hope it helps.
Dont forget to rate helpful posts
VIP Purple
Hope it helps.
Silver
just to more links for
just to more links for converting AP from stand alone to LWAP
http://targetcisco.blogspot.com/2011/01/converting-autonomous-access-point-to.html
Thanks a lot Sandeep
53
