Community Member
2710 Downgrade
Hello - I am now trying to downgrade my 2710. I began this process running 3.1.42. I upgraded to 5.1.30 but ran into issues sync'ing network designs with the 2710 on the WCS. So I upgraded the 2710 to 6.0.85 (WCS to 6.0.132)at which point I was able to synch designs.
However, due to an incompatibility with our RFid vendor's application I need to get the 2710 back to 3.1.42. I installed it according to the directions but I can't start the server. I get the following error.
[root@bidmc-location root]# getserverinfo
com.aes.client.AesClientException: Request to server failed, reason: java.security.PrivilegedActionException: com.sun.xml.messaging.saaj.SOAPExceptionImpl: Message send failed
at com.aes.client.AesClientAdminImpl.getServerInfo(Unknown Source)
at com.aes.server.cli.CmdGetServerInfo.run(Unknown Source)
at com.aes.server.cli.CmdGetServerInfo.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.zerog.lax.LAX.launch(DashoA8113)
at com.zerog.lax.LAX.main(DashoA8113)
I looked in the error logs and see the following errors.
========= Forking JAVA =============================================
LAX Version = 8.0
Sat Sep 12 16:10:43 2009
Database version (1536) does not match with SOLID version.
Possible causes for this error include:
- too old version of SOLID is used with this database
- the database has been corrupted
Date: 12.09 16:10:43
Product: Solid BoostEngine
Version: 04.50.0133
Operating system: Linux 2.4.21 ix86 MT
12.09 16:10:43 Server emergency shutdown.
Solid Database Engine process has encountered an internal error and is unable
to continue normally. Database version (1536) does not match with SOLID version.
Version: 04.50.0133
Is this a database version problem? If so, how would I get around it to get the 2710 back on 3.1.42..
Thanks for any input...
1 ACCEPTED SOLUTION
Re: 2710 Downgrade
I suspect the 5 version was not uninstalled properly.
In /opt/locserver/install from memory there is an uninstall script.
Run it and remove any locserver directory. Then re install 3.1 fresh
Re: 2710 Downgrade
Community Member
Re: 2710 Downgrade
So I ran the /*/opt/locserver/uninstall/uninstall*/ script. At the end
> of the process it indicated it could not delete everything.
> I was then unable to delete /*rmdir /opt/locserver*/. It indicated
> that the directory was not empty. So it was no deleted.
> I then reinstalled 3.1.42 from the installers directory.
> I was then able to start the server /*/etc/init.d/locserverd start */
216
