350 PCMCIA and WPA on XP SP2
I am converting a wireless network that was using EAP-TTLS to WPA. It works well from my laptop, which is using XP SP1, with onboard wireless nic. This works fine.
My customer is using Cisco 350 PCMCIA cards and is running XP SP2. I have the PC set for Window's to control wireless settings.
The problem is that I cannot get the option to select WPA under the wireless settings on these PC's running XP SP2. I tried updating the driver, and even installed a patch for XP SP2 that dealt with PEAP.
Does anyone know of any issues in which this will not work?
I even tried the 350 card on the XP SP1 machine and I can select WPA.
Seth
159
