Duplicate Post:
https://supportforums.cisco.com/discussion/12149926/3702i-ap-and-5508-controller
Is it true 7.6 is the oldest controller version for 3702 i APs?
Yes , the minimum version for 3702iAP to connect wlc is 7.6.100.0, check this matrix table:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
If we need to upgrade from 7.2.111.3, will this affect our current APs(3502i and 3602i)?
No, they will just upgarde there software version, and will reassociate to wlc.
Can we do a direct upgrade from our current version(7.2.111.3 to 7.6)?
Yes, you can directly upgrade to 7.6 version, check there the upgarde, table 7 : path:http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn76.pdf
When we upgrade the controller and install our new 3702i APs will there be any difficulties when roaming from our 3502is,3602is to our 3702is?
No, if all APs are connected and there is enough RF covrage and overap area then there will no problem.
Dont forget to rate helpful posts
