4402 with RADIUS admin authentication (mgmt)
I'm trying to get admin authentication, either through SSL or HTTPS access to controller, with a RADIUS Server. Radius is Cisco ACS 4.1. I've added the RADIUS in the controller and configured Cisco ACS. When I try to login into controller, logs on ACS specify a Passed Authentication.
I use the ACS to authenticate access to my routers successfully, therefore, Cisco ACS is running OK.
I tried with a different RADIUS server for controller admin access and get the same problem. On RADIUS, authentication is successful, but can't login in to controller.
Here is the debug aaa all output from the controller when I try to login:
(Cisco Controller) >Wed Apr 11 22:52:35 2007: Unable to find requested user entry for jimadmin
Wed Apr 11 22:52:35 2007: AuthenticationRequest: 0x137a0ac8
Wed Apr 11 22:52:35 2007: Callback.....................................0x10336ad8
Wed Apr 11 22:52:35 2007: protocolType.................................0x00020001
Wed Apr 11 22:52:35 2007: proxyState...................................00:00:00:2F:00:00-00:00
Wed Apr 11 22:52:35 2007: Packet contains 5 AVPs (not shown)
Wed Apr 11 22:52:35 2007: 00:00:00:2f:00:00 Successful transmission of Authentication Packet (id 6) to 172.16.227.28:1812, proxy state 00:00:00:2f:00:00-00:2f
Wed Apr 11 22:52:35 2007: 00000000: 01 06 00 48 00 00 00 00 00 00 00 00 00 00 00 00 ...H............
Wed Apr 11 22:52:35 2007: 00000010: 00 00 00 00 01 0a 6a 69 6d 61 64 6d 69 6e 02 12 ......jimadmin..
Wed Apr 11 22:52:35 2007: 00000020: 21 7a fd 54 da 87 55 a8 45 8e 67 ea 3f 85 fb 44 !z.T..U.E.g.?..D
Wed Apr 11 22:52:35 2007: 00000030: 06 06 00 00 00 07 04 06 ac 13 01 05 20 0c 61 69 ..............ai
Wed Apr 11 22:52:35 2007: 00000040: 72 2d 77 6c 61 6e 2d 32 r-wlan-2
Wed Apr 11 22:52:35 2007: 00000000: 02 06 00 33 91 a5 b9 ad ba 7a d4 ed 29 ce 8e 8e ...3.....z..)...
Wed Apr 11 22:52:35 2007: 00000010: 27 db fd 51 19 1f 43 41 43 53 3a 30 2f 32 64 30 '..Q..CACS:0/2d0
Wed Apr 11 22:52:35 2007: 00000020: 30 2f 61 63 31 33 30 31 30 35 2f 6a 69 6d 61 64 0/ac130105/jimad
Wed Apr 11 22:52:35 2007: 00000030: 6d 69 6e min
Wed Apr 11 22:52:35 2007: ****Enter processIncomingMessages: response code=2
Wed Apr 11 22:52:35 2007: ****Enter processRadiusResponse: response code=2
Wed Apr 11 22:52:35 2007: 00:00:00:2f:00:00 Access-Accept received from RADIUS server 172.16.227.28 for mobile 00:00:00:2f:00:00 receiveId = 0
Wed Apr 11 22:52:35 2007: AuthorizationResponse: 0x11c8a394
Wed Apr 11 22:52:35 2007: structureSize................................73
Wed Apr 11 22:52:35 2007: resultCode...................................0
Wed Apr 11 22:52:35 2007: protocolUsed.................................0x00000001
Wed Apr 11 22:52:35 2007: Packet contains 1 AVPs:
Wed Apr 11 22:52:35 2007: AVP[01] Class....................................CACS:0/2d00/ac130105/jimadmin (29 bytes)
Thanks!
James
1 REPLY
Re: 4402 with RADIUS admin authentication (mgmt)
If you need to log in to the WLC for management, you must set the return value "Service-type" to "Administrative". This has been recently included into the release notes, please see CSCsc96482
217
