5500 Wireless Controller with 7.6.130 - IPv6 address
We have configured ISE as the RADIUS for one of our SSID's. What we are noticing is a large number of clients are  getting assigned a ipv6 address.
We are not sure what changed and trying to trouble shoot ? We do not have ipv6 enabled on our DHCP . Is this something the clients are reqiesting ?
Do we need to change something on the Wireless Controller ? Appreciate your input.
1 REPLY
VIP Purple
Disable IPv6 globally on your
Disable IPv6 globally on your WLC. You can use below WLC CLI command to do this
config ipv6 disable
Rasika
*** Pls rate all useful responses ****
37
