5508 Wireless Controllers Freezing
Our controller get freezing every week at least twice, and do not know what is the reason. I am attaching the log for you to look at it. Last time happened was yesterday at around 13.00 pm.
Hall of Fame Super Silver
Looks like you have a bridge loop.  I'm guessing you don't ahve LAG configured or if so, you etherchanel/port channel is not configured right.  Can you post your show run-config
*Dec 07 13:48:07.103: %CAPWAP-3-DISC_INTF_ERR2: capwap_ac_sm.c:1505 Ignoring discovery request received on a wrong VLAN (5) on interface (13) from AP 00:3a:99:82:4b:40
-Scott
Re: 5508 Wireless Controllers Freezing
Thanks for your replay, attached is the run-config.
Ali
Okay... I see you have only one port connected on the WLC. How do you have the trunk port the wlc is connected to configured.
-Scott
here is the trunk config on the switch:
interface GigabitEthernet4/0/9
description "Connection to Wireless Controller"
switchport trunk allowed vlan 1,5,6,600
  switchport mode trunk
Why do you have vlan 1 on the allowed list.
Sent from my iPhone
-Scott
Vlan 1 is management vlan
Okay, what is vlan 6 then. I don't see that in the wlc. Can you verify that you don't have this command on the switch:
vlan dot1q tag native
Sent from my iPhone
-Scott
vlan 6 for APs managment, and we do not have 'vlan dot1q tag native' command on the switch.
You don't need vlan 6 then on your allowed list since the AP's will communicate with the management interface.
Sent from my iPhone
-Scott
Sorry Scott, Vlan 6 is for APs DHCP users access, and vlan 5 is the APs managment.
Well then remove vlan 5 from your allowed list.  I don't know if this will fix your issue, but I'm wondering if it might because of this error:
The AP's should join and communictae on the management interface, but you can see here that the WLC is seeing the join from vlan 5.
-Scott
Hall of Fame Super Gold
Depends on your switch.  2900, 2940/2950/2955, 2960/2960S don't need dot1q command because it is on by default.
Silver
What exactly is your symptom?
"freezing" means what?  Lock up and needs a reboot?  Servicing clients but can't manage it?   Does it self-recover? (does it crash and reboot?)
And what firmware are you running?
789
